rear spoiler installation instructions
i recently purchased a gm full width rear spoiler (ron fellows z06 edition) for my 07 mn6 c6 coupe. i should be getting it any day now from gene cullery. could someone explain how it is installed? im having difficulty trying to locate the bolts that hold the stock spoiler on.
i have read on this forum where some guys use double sided tape and some use bolts and some use both. right now i need to know how to remove the original spoiler. any help would be greatly appreciated.:smash: |
Have you looked at the C6 FAQ sticky? It's got quite a few DIY links in it.
Remove one of the taillights. The spoiler is accessed from the light hole.
Originally Posted by JOHN TOMARO
(Post 1560966443)
I also bought my gm racing spoiler from Gene and you should be receiving detailed instructions along with the template for drilling the holes. Like others have said, there are a couple of good write ups with pics on the forum as well. :thumbs:
(Post 1560966443)
i have read on this forum where some guys use double sided tape and some use bolts and some use both. right now i need to know how to remove the original spoiler. any help would be greatly appreciated.:smash: The "search" is your friend....my step by step DIY from September 2006 :thumbs: http://forums.corvetteforum.com/show...6+race+spoiler |
I had to make my own template for my install :(
Remove the tail laghts. (#10 Torx)
Accessing the bolts (2 on each side) through the inner tail lamp holes, use a 10mm socket (on a flexable handle works well) to remove the nuts. Remove the OEM spoiler. The new full length spoiler will require drilling 4 holes. Use the supplied template. The center stop lamp will transfer from the OEM to the new piece. There will be two small screws supplied that will secure this piece in place of the two studs that were used originally. |
You MUST make a small "cut" for the install. The center rectangular hole that is there now, must be enlarged ever so slightly to allow for the new electrical connection to fit. Use a razor knife and VERY carefully cut a small section of the current hole. The cut is TOWARD the front of the car and DOES NOT go ANY further than the area where the "wall" of the hole sits. In other words, only the "floor" of the hole and NO vertical sections of the current hole area. This is like an 1/8th of an inch of material to be removed and as wide as the narrow part of the hole. The original "hole" is something like 1" by 2" You will end up 1" by 2 1/8". Do not cut any vertical areas out of the spoiler hole area.
Did that make sense? Remove all 4 tail lights to remove and install the new spoiler. I did it all in less than an hour. It is very simple just read the instructions twice. Do it in you mind first and then go for it. Elmer |
It's an easy installation. The only problem I had was the two center studs that are reused from the original spoiler did not extend down thru the body far enough to attach the nuts to. I added flat washers to these studs and that solved the problem. I like the look of the spoiler, I think it adds to the rear lines of the car. I did mention this problem to the engineer in charge of the GM after market parts when I met her at the C6 birthday bash in April at BG. You'll do just fine on the installation. Just read thru the instructions twice and remember these were translated from Chinese. :rofl:
I had no problem with the length of the center studs.
Mine is on order from CFL Motorsports and I can't wait for it to arrive. They are painting it AO for me so I don't have to find a local body shop to do it. I hope it looks OEM. Then I will add the tinted brake light covers and I think the back will look awesome.
RBYCC, your writeup looks excellant! Man is it gonna be scarry drilling holes in my 2 month old, waited all my life for, Corvette :eek: :eek: :eek: |
Originally Posted by pcervone
(Post 1560971474)
Originally Posted by burtonbl103
(Post 1560969206)
You should have bought it from me! Shame on you for switching! :toetap: |
I'd like to start up an install section on my site for this stuff. If anyone has a detailed written report with pictures and wants to give me the permission to put it on the site contact me.
Originally Posted by McClendons
(Post 1560971566)
Glad that CFL was able to help you. The one they did for me was a pefrect match and gave good service. Fairly quick too, given a custom painted part
Originally Posted by keg
(Post 1560970106)
I tried for a little while to get all four original studs to work, then decided to read the instructions :) |
Originally Posted by Atomic-Vette
(Post 1560972661)
actually if you look at the instructions, it shows not using those two bolts. You use the two supplied bolts instead to hold the light in and two of the four remaining studs to hold the wing on.
You remove the center two studs that hold the brake light in the original spoiler. Remove the brake light. Install the brake light in the new spoiler with the small screws that came with the new spoiler hardware not the studs from the original spoiler. Screw the removed center studs into the new spoiler along with the four supplied "slide in studs" that will go into the newly drilled holes. When done you have the 4 new studs on the outer ends of the spoiler and the reused studs from the original brake light that now will go thru what were the outer holes from the original spoiler. No need for any washers on my install. Plenty of stud to accept the nut. The center holes from the original spoiler (that also held the brake light) are not used with the new spoiler.
Originally Posted by Walt White Coupe
(Post 1560977892)
