Water pump replacement....
Ok, first symptoms....intermittent squeaking when cold and an occasional constant squeak while driving. I looked at it today and it appears I have coolant on the front leaf spring and on the balancer...nothing under the car..the reservoir is low...so I am guessing the pump is going bad. I thought these pumps leaked thru a weep hole on the bottom when they go out..is that what I am seeing even though I have nothing under the car??
Anyway..how long to remove and replace? Thanks |
Not sure on the time, but here is the shop manual steps:
Water Pump Replacement Removal Procedure Caution Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components. Disconnect the negative battery cable. Disconnect the intake air tempeture (IAT) sensor connector. Disconnect the mass air flow (MAF) sensor connector. Remove the air intake duct/cleaner assembly. Remove the accessory drive belt. Refer to Drive Belt Replacement in Engine Mechanical. Drain the cooling system. Refer to Draining and Filling Cooling System . Remove the radiator inlet and outlet hose clamps from the water pump. Remove the radiator inlet and outlet hoses from the water pump. Remove the heater hose clamps from the water pump. Remove the heater hoses from the water pump. Perform the following steps on vehicles equipped with a bolt on water pump pulley. Remove the water pump pulley bolts. Remove the water pump pulley. Remove the six water pump retaining bolts from the engine block. Remove the water pump. Installation Procedure Clean the water pump gasket surfaces. Install new water pump gaskets with the tabs up. Install the water pump to the engine block. Notice Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems. Install the water pump bolts into the engine block. Tighten Tighten the water pump bolts to (first pass) 15 N·m (11 lb ft). Tighten the water pump bolts to (final pass) 30 N·m (22 lb ft). Perform the following steps on vehicles equipped with a bolt on water pump pulley. Install the water pump pulley. Install the water pump pulley bolts. Tighten Tighten the water pump pulley bolts a first pass evenly to 10 N·m (89 lb in). Tighten the water pump pulley bolts a final pass to 25 N·m (18 lb ft). Install the heater hoses to the water pump. Install the heater hose clamps to the water pump. Install the radiator inlet and outlet hoses to the water pump. Install the radiator inlet and outlet radiator hose clamps to the water pump. Fill the cooling system. Refer to Draining and Filling Cooling System . Install the accessory drive belt. Refer to Drive Belt Replacement in Engine Mechanical. Install the air intake duct/cleaner assembly. Connect the MAF sensor connector. Connect the IAT sensor connector. Connect the negative battery cable. Tighten Tighten the negative battery cable bolt to 15 N·m (11 lb ft). Program the Transmitters. Refer to Transmitter Programming/Synchronization in Keyless Entry. Start the engine. Inspect the water pump for leaks. |
Thanks..I have a manual....look pretty straight forward...:cheers:
. . . . . . . . . . Living up to it's name :( <----------------------------- |
Water pump is pretty easy. I have a stocker that i took off for an electric waterpump if you're interested...
Hardest part is scraping that damn gasket off the block!:willy: What a PITA :D :thumbs:
Originally Posted by Bill Curlee
(Post 1561062280)
I knew that BTW |
Originally Posted by yellowvette837
(Post 1561061840)
. . . . . . . . . . Living up to it's name :( <----------------------------- it will be ok..BTW I ordered it earlier...forgot to tell you ;) |
(Post 1561062280)
The later years used MLS water pump gaskets which remove cleanly with nothing to scrape. Not sure what year they started, but my 01 had them. If this is for YV's car, it shouldn't be an issue. :cheers: |
1 word:
EVANS...:yesnod: |
Originally Posted by Y2Kvert4me
(Post 1561065150)
Only an issue on the older C5's.
The later years used MLS water pump gaskets which remove cleanly with nothing to scrape. Not sure what year they started, but my 01 had them. If this is for YV's car, it shouldn't be an issue. :cheers: of course it is my car :rolleyes: |
Originally Posted by pewter99
(Post 1561064248)
:leaving: |
(Post 1561065150)
I know that you have already bought yours, but here's and FYI for anyone reading this that is getting ready to do the same thing. If you plan on getting a different thermostat, get a water pump for an '04 vette (same as an LS2). This water pump uses a standard thermostat that you can buy for $5-$10, instead of the one piece thermostat/waterneck that costs $50-$60.
Originally Posted by 'VETTE PHASE
(Post 1561067857)
