Originally Posted by Da Mail Man
(Post 1561910800)
.....humnnn...ok, what happens when you have 200+lbs of pressure on a high side?...ya think the cap will keep it in or even stay on?...
Tom Piper |
Leaking schrader valves might be fairly common. In making my rounds yesterday visiting the usual auto parts chain stores I noticed many featured R-134A displays up front along with other fast moving A/C supplies like refrigerants, oil, leak detecting dye, A/C system stop-leak, R-134 can with gauge & quickie low side charging hose and a rack full of blister pack schrader valves!
[IMG]http://i121.photobucket.com/albums/o...9412414_tp.jpg[/IMG]
The above is a schrader valve tool purchased recently at a bike shop in Ft. Lauderdale. I used it last week-end to tighten up the valve on my fuel rail.:thumbs: |
Originally Posted by Tom Piper
(Post 1561911236)
Yes, even at 400.
Tom Piper |
Originally Posted by elefkow
(Post 1561914358)
(Post 1561914512)
......NO way......they are designed only to keep dust and dirt out...
At 400 Pounds Per Square Inch pressure inside the A/C system, there would be 10% of that, or 40 pounds of pressure, on the valve cap. Tom Piper |
(Post 1561914556)
For an example, let's assume the cap has a flat end inside with the schrader valve that equates to 10% of a square inch.
(Post 1561914764)
.......sorry, don't buy it!....:nono:
Tom Piper |
96 LT1
I had to have my A/C evacuated and re-charged last month. I tired adding 134 (thought system wasn't blowing cold enough) and the schrader valve wouldn't reseal. It continued to allow the 134 to spit out, even with the cap screwed on. At the A/C shop, the owner told me he sees that problem very often. Seems that many times the valve won't re-seat, so it has to be changed. So the remaining refrigerant in the system has to be released, system put on a vacuum pump, new valve installed, pressure tested and system recharged. Cost me a couple of hundred $. I had to have it repaired since it was 100+F at the time. Jake |
(Post 1561914809)
I can't think of a single thing to add.
Tom Piper |
Unless that little rubbery butt plug failed completely I don't think the cap would ever see the full wrath of 200psi. While a small leak from that plug and the small volume between the plug and the cap itself could yeald higher pressures, I don't think it would blow it's cork.
Originally Posted by ineVETTEable
(Post 1561924559)
Actually, systems just blow up at the weakest part. There is a pressure relief valve on the rear of the head and the Nippo compressor seems to give up it's front seal rather easily. Otherwise, power is cut at 400 psi (you hope - no way to test some of the early switches). Point is that leaks you can see are leaking a lot (and maybe sucking something in when it's working).
(Post 1561914530)
.....i have one of these also but, that is good only for tightening or loosening...not good to replace a shrader w/out loosing the charge and if the shrader is leaking and is already tight, this is little good....
