Very Basic HOWTO - Get rid of "SYS" for aftermarket stereo
This may be somewhere around here already, but I finally fixed the flashing SYS light caused by my aftermarket stereo. All told it was about a $5 project.
Supplies needed: Heat shrink tubing that fit over 20 gauge wire One red Male quick disconnect (yes this one is blue, you need the red one) http://i187.photobucket.com/albums/x...disconnect.jpg One blue "T Tap" http://i187.photobucket.com/albums/x...k_771/ttap.jpg Two "1k, 1/2 Watt" resistors (Radio Shack) Assembly I did the easiest thing I could fine, but it still required cutting the factory harness. I first took the red quick disconnect and the two resistors and crimped them together. The red disconnect is for 20 gauge wire but the leads on the resistor are much thinner then that so both leads will fit inside the crimp of the disconnect with no problem. Both resistor should be sticking out of the disconnect when finished like a 'Y'. I then cut the GRAY/BLACK STRIPE and the PURPLE/WHITE STRIPE wires from the factory harness and stripped the ends about 1/2 inch. I put 1 piece heat shrink tubing over each of the wires. The tubing should be long enough to cover the splice we are about to make plus resistor completely all the way to the crimp on the disconnect. This makes it a little nicer and less likely to short out something. Then twist one wire to one of the resistors and the other wire to the other resistor. You can solder if you want, but I don't think a butt connector will crimp well to the thin resistor lead. I just twisted them together. I pushed the heat shrink tubing over each assembly from the wire splice all the way up to the end of the disconnect and heated it. I think this creates a pretty good connection. Last is to crimp the "T Tap" onto the red power lead. Make sure the tap is within about a foot of the radio. The wires that you spliced eariler aren't very long. Anyway this is an ignition switched power connection. Once you crimp the tap into place just plug the disconnect into the T-Tap and you are done. Hopefully there is no SYS light after this. |
See C4 audio FAQ.
Originally Posted by Vis Croceus
(Post 1562244754)
See C4 audio FAQ.
If this is helpful, then great. If it gets buried, that's fine too. |
SYS Light After Radio Install
2 Attachment(s)
Originally Posted by black_771
(Post 1562244574)
Before you begin...
What A/C controller do you have? Manual or Automatic? If Automatic, you may not need the resistor fix.
Originally Posted by Klaus-96
(Post 1586140637)
Originally Posted by Cutolds350
(Post 1586141413)
I've got the automatic climate controller.
I have owned 2 separate '96 Corvettes. The first was a base model with the manual A/C. When I replaced the radio with an aftermarket model, the sys warning was a problem and required the resistor fix. I later owned a '96 CE fully loaded, with the automatic A/C. When I replaced the radio with an aftermarket unit, it did NOT require the resistor fix. The sys warning displays because the computer does not see a load on the illumination circuit. If you study the wiring diagrams, the radio AND the automatic A/C controller both draw off that circuit. The manual A/C controller does not. Therefore, because the automatic A/C controller is still drawing/completing the illumination circuit, the sys warning does not appear. At least that is my theory. Why don't you test it before the install. With the radio disconnected, start the car and turn on your headlights. Set the dimmer control in the center position. Give it a couple of minutes. Do you get the sys warning? |
(Post 1586146919)
I would try it without the resistor fix, as long as the digital display is working properly in the automatic A/C control.
