Originally Posted by stinger12
(Post 1571726431)
Dude, we still need to talk on the phone!!! I totally forgot about that...woops.
http://www.corvetteclub.org.uk/image...odyoff/347.jpg |
6 Attachment(s)
Finished bonding the floor pan to the bottom of the rear tub. This job was very tedious, and required a ton of prep...I never want to do this again! Ever tried fiberglassing upside down:willy: Tomorrow I will drill the holes out for the new rivets, and pop them in. Then I will be done with it.
Next project is the #4 body mounts (fiberglassing) and installing the cover reinforcements on them. I'm extremly close to finishing the underbody - less than a month before I get to install the body! Attachment 48157791 Attachment 48157792 Attachment 48157793 Attachment 48157794 Attachment 48157795 Attachment 48157796 |
I can't decide whether or not I should undercoat my underbody. I'll definitely undercoat just above the tires to prevent spider cracks. The bottom of the vette is spotless now - not one spot is uncleaned. You could eat off of it. I want to keep it that way.
Suggestions on a paint color to go with (if I decide to paint it)? |
I just paint the underbody & the wheels house after I clean up with silk black paint but will spry some pitch like (I don't no the name for this black staff in English) on the wheels house after I install all the reinforcement brackets that I took out from the body to restore/galvanize them.
Avner |
Back in the day, when we wanted a painted surface to be durable, we shot it in Dupont Imron. It's a sprayed paint, but is just short of powder coating in terms of strength. I'm not even sure you can still buy it. The stuff is toxic as hell.
6 Attachment(s)
I finished the floor pan to rear tub bonding/rivetting. I countersunk the screws holes (the ones which were used as clamps during bonding) and packed them full of marinetex and sanded them smooth. Everything is getting a coat of undercoating once finished. If this were the outside of the body, then I would have glassed those holes shut...but this is the underbody. This bonding adhesive is insanely strong...I still can't believe how good the stuff is.
Attachment 48157741 Next I finished sandblasting the pillars (the areas getting covered by the access covers). I masked them off, and gave them a coat of krylon rust tough enamel. Just these two areas are getting spray painted - the rest of the car is getting sprayed with my new paint gun and some high end primer. Attachment 48157742 Attachment 48157743 Attachment 48157744 Then I started to prep some cracks for fiberglass repairs. I also masked off the inside of the #4 mount, and applied bondo on the backside...a trick that works awesome! http://i6.photobucket.com/albums/y23...r/DSC05592.jpg Attachment 48157745 Attachment 48157746 I still have a ton of work to do before I get to reunite the body/frame. Once again, I am beat/extremely exhausted. |
1 Attachment(s)
These pieces were still in good shape (seatbelt reinforcements). Water usually collects behind them and then they rust out. I sandblasted both sides (looks a little funny...there is still some original plating on them, which is some pretty tough stuff), then applied a ton of bonding adhesive on the backside. I pressed it tight against the fiberglass until it oozed out and sealed it to the tub. No water will be able to get to it now. I sandblasted the fiberglass before I bonded the reinforcements in place.
http://i6.photobucket.com/albums/y23...r/DSC05608.jpg http://i6.photobucket.com/albums/y23...r/DSC05612.jpg Attachment 48157734 |
I finally found my second pair of US Indys on Ebay the other day! I bought them last night - now I need to polish them:)
7 Attachment(s)
I sandblasted these two areas on each B-pillar. This is where the access cover butts up against, and GM never bonded them there. I am going overkill on everything - I never want to do this again.
Attachment 48157687 Attachment 48157688 Next I prepped one of the access panels for fiberglass repairs. I stripped the panel of all the crap and crud last night. Attachment 48157689 Here is the repair... Attachment 48157690 And here is the left #4 mount all glassed up... Attachment 48157691 This area needed some glass work as well. It was previously repaired by GM using a 1/2''X1'' piece of fiberglass cloth... Attachment 48157692 I sandblasted and powdercoated these two covers for the access covers in front of the rear tire... Attachment 48157693 Time to get some sleep:willy: |
I realy like the additional prep in this car. It will weather time better than origional.
Originally Posted by FatCat Blue 80
(Post 1571869491)
Greaaatt job. :thumbs: I restored a Piper Cub when I was your age. Took two years. No rush. When I got tired, I took off some time. It was always there when I got back to it. You only get to do this once. Why not enjoy the pleasure of your work. BTW I flew that plane from Philly to LA and back. (45 years ago). :D:D:D:D:D:D
(Post 1571870162)
Lets just hope I don't run out of gas before I reach the final destination...its starting to wear me out physically and mentally. Gotta keep push'n myself!
We all enjoy seeing your updates and I know I am envious of your abilities; I'd love to have the balls to tackle doing something like this to my '69 coupe. |
Originally Posted by 1996Z15
(Post 1571877350)
Keep plugging away but, don't make it a chore. Like the previous poster stated, this should be enjoyable and something that you'll be able to take great pride in once you're done. It looks like you're close to starting the reassembly process where you'll really start to see a car emerge from all of the parts you've been working on and assembling.
Originally Posted by Thmprr
(Post 1571884743)
:iagree: When I find that it's not fun anymore during my restoration of my 57 2dr Sport Coupe, I take a few nights off, then recharged, I'm fine for a while. I liken it to eating an elephant a bite at a time! I have 3000 man hrs into it so far, and looks like anothe 200 to go.
Heck yes!!!! Everyone has already said it, but I'll say it once more.
Amazing work...can't wait to see it progress. I've been on mine hard the last two months or so. On top of working 70-80 hours a week...still do a couple hours each day and 8-14 hours on my one day off. I can totally understand the exhausted part. A bigggg pat on the back from me!!! Mark |
(Post 1571870162)
3 Attachment(s)
Woohoo... I'm almost done the left #4 mount!
Attachment 48157655 Attachment 48157656 Attachment 48157657 Ever tried to prep the inside of a #4 mount for fiberglass...talk about a tight fit:willy: |
Originally Posted by vagabond407
(Post 1571885662)
4 Attachment(s)
The #4 mounts are almost done...I just need to glass the outside of the passenger one.
Attachment 48157621 Attachment 48157622 Attachment 48157623 Attachment 48157624 |
