Carter Carb Date Codes
I need a refresher on the cast #'s on the C1 Carter carbs. I think they have a date code separate from the tag attached. Is this so, and if so, how is the date noted and located?
Thanks |
The only date code on a WCFB is on the tag. AFB's had a date code stamped on the edge of the baseplate - letter for the month, number for the year. :thumbs:
OK, I have two WCFB's that are identical except the small cast # on the left front is different. Example on one of them is 0-1517, and the 1517 has a circle around it. What does this number signify?
Originally Posted by SMSC1
(Post 1562939486)
(Post 1562939486)
:iagree: Does anyone know of a source that lists all of the casting numbers and their application?:willy:
Originally Posted by vettepoor
(Post 1562941448)
I have no idea what mine are off of. Rear carb has 15/16 venturis, front carb has 1". :crazy: Amazingly, it seems to run pretty well. Maybe the difference "evens out" the lean/rich problems these seem to have between the front and rear cylinders! :lol:
(Post 1562941647)
The NCRS CD has a good list of all the WCFB 1x4 and 2x4 carbs and component numbers thru the '65 model years. It's a handy list for ID'ing these carbs. :thumbs:
Originally Posted by ls6racer
(Post 1562944441)
BTW, your black 57 looks great on the dragstrip in your profile picture! |
i can't get the CD to work on this computer. but i don't think it had the issue info.
i have the carb numbers info printed out for reference. but i have the info also saved in a word document. i can email it to you. i'll try tomorrow on another computer. and thanks for the compliment! :thumbs: |
(Post 1562960487)
i have the carb numbers info printed out for reference. but i have the info also saved in a word document. i can email it to you. i'll try tomorrow on another computer. and thanks for the compliment! :thumbs: Spring '84 Winter '92 Spring '96 |
1 Attachment(s)
Try this - Corvette WCFB "numbers", from Gary Hodges, NCRS carb "guru". :thumbs:
Originally Posted by JohnZ
(Post 1562966918)
(Post 1562966918)
