rear fender flares
does anybody make a rear fender flare that covers the tire?
thanks,
but already have them, the L-5 flares don't cover the rear of the tire even with the splash guards, looking for something a little more fuller. |
I just modified a set of C6 Z06 factory flares to fit my C5. I don't have a picture but the application was so sweet!!! Do a search in the general section under C6 fender. :cheers:
ACP Corvette, otherwise know as Corvette Race Bodies. They make pieces that Lou G has used on his World Challenge Corvettes that cover the entire rear wheel. These are truly race inspired for proper aerodynamics much like the C5R & C6R pieces. All Business, available in Carbon Fiber as well :cheers:
http://www.corvetteracebodies.com/wo...ice%20list.htm |
Originally Posted by ryns03zo6
(Post 1563703186)
thanks,
but already have them, the L-5 flares don't cover the rear of the tire even with the splash guards, looking for something a little more fuller. I have the 3/4" flared ACP fenders and SPWCGT rear facia with molded 1" spoiler. http://img.photobucket.com/albums/v1...nderflare4.jpg I run 18x13" rims ( 3/8" spacer on longer ARP studs) with 18x335/30 Hoosiers. Tires are almost 14" side wall to side wall. |
I put a set of c6 zo6 mud flaps on my c5 zo6.
http://i168.photobucket.com/albums/u...d/DSCN2863.jpg http://i168.photobucket.com/albums/u...d/DSCN2862.jpg This helps me alot at the track, no more rubber on the rear fender. |
do you tihnk you could send me more pics of your vette to rbdusmc0311@hotmail.com
rear splash guards
Originally Posted by wanttospeed
(Post 1563713531)
http://i168.photobucket.com/albums/u...d/DSCN2863.jpg http://i168.photobucket.com/albums/u...d/DSCN2862.jpg This helps me alot at the track, no more rubber on the rear fender. Did the have to be modified. |
:bigears
Originally Posted by 03sixspeed
(Post 1567507352)
I like the look of those factory splash guards. Were they hard to install.
Did the have to be modified. aftermarket ones do not have to be modified. the down side is they cost about $200 w/o shipping. |
Originally Posted by jdmvette
(Post 1568190625)
OEM ones absolutely have to be modified. the plus side is they only cost about $50 shipped.
aftermarket ones do not have to be modified. the down side is they cost about $200 w/o shipping. That was back in 05. Noe that did not count all the prep work that was needed. Jell coat, sand, jell coat, sand, primer, sand, paint. Mount, blend paint to match. Any after market body parts are not bolt on and go. They all need some body prep work. |
Originally Posted by AU N EGL
(Post 1568190693)
OEM fenders are much more expesive then that.
When I did my fender flairs I think the ACP ones were less expesive then the OEM fenders. Not by much but $20 or so. That was back in 05. Noe that did not count all the prep work that was needed. Jell coat, sand, jell coat, sand, primer, sand, paint. Mount, blend paint to match. Any after market body parts are not bolt on and go. They all need some body prep work. |
Originally Posted by fastvetZ06
(Post 1563703513)
(Post 1563702390)
http://forums.corvetteforum.com/c5-t...nels-pics.html |
Sweet!!
(Post 1563713531)
i put a set of c6 zo6 mud flaps on my c5 zo6.
http://i168.photobucket.com/albums/u...d/dscn2863.jpg http://i168.photobucket.com/albums/u...d/dscn2862.jpg this helps me alot at the track, no more rubber on the rear fender. |
APSIS Splash Guards - about $100 each...
http://dev.choreo.com/VetteForum/SplashGuards_08.jpg http://dev.choreo.com/VetteForum/SplashGuards_02.jpg |
Originally Posted by Choreo
(Post 1570422103)
(Post 1570422300)
damn your pics are always badass. :thumbs:
