What is the age of my AC Delco Battery?
I just bought my 2000 used and I'm going through all the normal checks. I discovered quickly that the coolant probably hadn't been changed...ever by the looks of it! I addressed that issue yesterday.
I suspect the battery might also be eight years old. If so, then I might replace it in the next few months. How do I tell the age of an AC Delco Battery? Mine is marked : AC Delco 78-6YR Serial Number: 833571 There is also a P followed by a stamp that reads 056N Edit: Nevermind. I found the answer. If anyone is interested. Looks like my battery was made in May of 2006. How do I read the warranty date code on my battery? The warranty date code is located on the top label of the battery. The first character is either a P or S. The next two digits determine the month, the third digit is year and the fourth digit indicates the manufacturing plant. For example, P 094N means the battery was made in September 2004 in the New Brunswick factory. |
Deciphering codes on ac delco battery
Hay thanks for the info. I was trying to figure out my batterys point of life, and it's got a number on the label of ACD 75/60 and below that is the # S116P so that means the battery is a 5 year battery and it was made on November of 2006 at the 'P' plant Now I'm wondering if I should muster through another winter with it or get a new one. It was in my car( My C-4) when I got it. What do you think? Thank you ! :flag:
Originally Posted by killain
(Post 1572168600)
(Post 1572168600)
5 year battery and it was made on November of 2006 at the 'P' plant Now I'm wondering if I should muster through another winter with it or get a new one. What do you think?
And most importantly the new batteries don't leak
Thanks for all info---jerry
Originally Posted by DeeGee
(Post 1572179804)
Well known issue around 98-01 stock ac delco batteries that the positive post would come off on the battery causing a leak. |
Quote:
Originally Posted by DeeGee And most importantly the new batteries don't leak Not True at all "Well known issue around 98-01 stock ac delco batteries that the positive post would come off on the battery causing a leak." But then this is almost 2013, just how many of those 12 year old batteries are still in service?:eek: |
Originally Posted by corvettebob1
(Post 1582139743)
98 Battery
I have a 98 and my battery lasted 8 years before I put a new AC Delco in. This battery is still in and working fine. I never used a battery tender on them.
(Post 1572179804)
(Post 1582139743)
Just pulled battery out of my 2004. It is a ac delco. I think it is original.
Here is all the info I could find. cat# 0925 590 cca 86-6yr Prick punched on top were 4021f54 Stamped on side were 4d16by1e No other ident can be found----looks goofy to me, help---thanks--- I will be replacing battery anyway. Curiosity getting to me. |
Originally Posted by 2079
(Post 1572170107)
At the price of a battery I personnaly never try to outlast them.The first time you get standed you pay for it just in wasted time and ......Its your call but do the math of the cost per year for reliablity.:thumbs::thumbs:
I store my car during the winter, and I know while it's good for the car, it's an "iffy" deal for the battery. I do put a charger on it for 10-20 minutes each week, usually when I've got the snowblower out to clear the driveway, but still, after 4 years, I usually wind up replacing it.... |
Originally Posted by vetteman138
(Post 1582149393)
I believe that the LEAKAGE issue has to do with if the POS and or NEG terminmal was abuse. Some were just plain outright defective and leaked right thru the bolt hole. You have been warned. On a positive note,, the battery in my 97 F150 lasted 12 years and was in the truck working fine when I sold it. BC |
Didn't anyone notice that this thread is nearly 5 years old? :eek:
If you are a gambler, trust A/C Delco batterys. If you have had the problem of their leakage you would definetly have the intelligence to use another brand. There are several other gel battery manufactueres. Been there did that.
A word to the wise is sufficient. |
Originally Posted by Quicksilver Vert 01
(Post 1582356666)
Battery date ???
I just bought a 2005 and getting ready to go on Hot Rod Power Tour and don't want any problems. I looked at the AC Delco battery and the date code is S104P. Now I know that is was made in Oct but is it 2004 or 2014? The battery looks new with a little dust on it but so does the rest of the car.
(Post 1582356666)
:cheers: |
Originally Posted by wrrn73
(Post 1589500511)
The warranty date code is located on the top label of the battery. The first character is either a P or S. The next two digits determine the month, the third digit is year and the fourth digit indicates the manufacturing plant. For example, P 098N means the battery was made in September 2008 |
