How do you Re-Program Key fob
I ordered a Remote key fob from an auction site. Can someone tell me how to reprogram a used key fob? I have a number 1 that came with the car. The one I ordered is a number 2 (differenr serial number from the number 1) Thanks in advance :cheers:
Try sitting in the car with the engine off and holding down the lock and unlock buttons down for 7 seconds. The car should recognize and store the fob freq. There is a more detailed instruction in the manual if this doesn't work. Chuck.
Thanks for the info, c5chines, Do you have the instructions in the manual that you could post also?
P.S. I appreciated the additional post on the "welding". That was important info. I should have gone into more detail but didn't want to get into a back and forth with the experts that lurk around here. :cheers: |
Hit options until the DIC message is blank
Hold Reset until it response The two options on this menu are tire training and fob training Get to the fob training section, then hit reset again Hold lck and unlck until it response with 1st fob learned Repeat for second fob 11 seconds is how long it takes for each fob (seems like a long time when sitting there waiting) |
jedblanks, Thank you!:cheers:
Yeah man, just hold down both buttons and wait for the horn to blow..
As you've probably found out by now, you can't program a fob to your car by holding down the lock and unlock buttons and waiting for the horn to honk. That only resyncs a current fob to your cars rolling frequency (to help with anti-theft). You program a new fob by using the DIC and following the fob training instructions. (which includes holding down lock and unlock buttons) If it loses sync with the car, you can resync using the first procedure. If just holding down the buttons worked, anyone with a fob could walk up to your car, hold down their buttons, wait for a honk and open your car.
programming FOBs
Originally Posted by Twospeed
(Post 1564934166)
!. Turn ignition on. 2. Turn radio off. 3. Press DIC RESET button. 4. Press OPTIONS until display is blank. 5. Press and hold RESET for 3 seconds. 6. Press OPTIONS until FOB TRAINING displayed. 7. Press RESET to begin programming sequence. 8. Simultaneously press and hold LOCK and UNLOCK buttons on fob for 13 seconds. Message will appear on DIC when remote is programmed. 9. Turn ignition off and remove key. 10. Test remote. This works on 2001 Corvette and prob others. 2. |
Don't forget that all the key fobs are not the same. It looks like from what you say you ordered the correct one. They are broken down into two types: 1997 through 2000, and 2001 through 2004.
The fobs use the receiver (RFA) which is shared with the TPS system. The system operates at a different frequency for each group. From Gene Culley's website it looks as though there may even be a third type: ||--Genuine GM Key FOBS/Transmitters--|| 10253839 – 97-99 – $79.20 10432147 – 00 – $61.20 25695954 – 01-04 #1 – $66.30 25695955 – 01-04 #2 – $66.30 If you're having trouble reprogramming through the DIC it's worth checking you have the correct #2 fob (25695955) for your 02. |
Download your owners manual here. Save to your hard drive for future reference. Fob training is on page 2-12.
program FOBs
(Post 1564934166)
1. Turn ignition on. 2. Turn radio off. 3. Press DIC RESET button. 4. Press OPTIONS on DIC until display isd blank. 5. Press and Hold RESET button for 3 seconds. 6. Press OPTIONS button until FOB TRAINING is displayed. 7. Press RESET button to begin programming sequence. 8. Simultaneously \press and hold LOCK and UNLOCK buttons on FIRST remote for 13 seconds. Message will appear that 1st FOB programmed. *(*(at this point on the SECOND FOB press and hold LOCK and UNLOCK simultaneously. Message will appear on DIC that 2nd FOB programmed. 9. turn ignition off and remove key. 10. test remotes. (This will work on both FOBs to open doors, lock doors, open hatch, and IF.....IF you have a #1 and #2 FOB they will set the drivers seat to #1 or #2's preference.) If you happen (as I did have two #2's you may use both #2's to unlock/lock/hatch...but NOT seat preference.) |
You guys realize you're answering a question asked almost 3 years ago? I'm sure he knows by now.
Originally Posted by 65GGvert
(Post 1576169642)
:lol:
2008 C-6
Matching Transmitter(s) to Your Vehicle Each keyless access transmitter is coded to allow only transmitters programmed to your vehicle, to work. If a transmitter is lost or stolen, a replacement can be purchased and programmed through your dealer/retailer. Your dealer/retailer can reprogram your vehicle so lost or stolen transmitters no longer work with your vehicle. Each vehicle can have a maximum of four transmitters matched to it. To match a new transmitter to your vehicle when you have a recognized transmitter (two recognized transmitters are required for Canadian owners): 1. The vehicle must be off. 2. Have the recognized and new, unrecognized transmitters on your person. 3. Go to the rear of the vehicle and insert the vehicle key into the key cylinder located above the license plate. See Hatch on page 2-14 for more information on the key cylinder. 4. Open the trunk. 5. Turn the key five times within five seconds. 6. The DIC will display READY FOR FOB #X, where X can be 2, 3 or 4. 7. Place the new, unrecognized transmitter in the glove box transmitter pocket with the buttons facing towards the passenger’s side. 8. Once the transmitter is programmed, a beep will sound. The DIC will display READY FOR #X, where X can be 3 or 4, or MAXIMUM NUMBER OF FOBS LEARNED. 9. Press the Acc. button (ignition switch). |
This old thread just won’t give up! It’s so old, it has now morphed into a C6 :crazy2::D
Originally Posted by 87SAM
(Post 1576775648)
(Post 1576169642)
'04 fob
Originally Posted by Yello95
(Post 1576778156)
:lol::lol::lol:
Thanks in advance |
http://ad.doubleclick.net/click%3Bh%...partshouse.com
---------------------------------------------------------- http://www.gmpartshouse.com/download...04corvette.pdf |
