Originally Posted by AORoads
(Post 1565688865)
this has got to be tongue in cheek. OF COURSE the people who are saying it drones are talking about either a pulled fuse or a control box leaving the flap open at the "resonance" rpm. you betcha! :rofl: :cheers:
B&B PRT is thier headers or stock system only. If you have Kooks with cats it will not work.
I had B&B Rt. 66 with kooks 1 3/4 and high flow cats and the drone which was just at 1,500 made me switch to Corsa Sports. The Corsa's have zero drone, but they are very loud at WOT. When I had the Corsa and B&B on the floor next to each other the build difference was incredible. B&B is built like brick **** house. Corsa built well, but about 20 lbs lighter. |
you can swap out your rear end--
you can change your shift points a bit with a tune- run lower gear out longer or use your gear shifter more if you hiway alot get a rear and a tune that will fix most of it |
