Egr Delete And Some Hose ...
Guys what effects can cause if i buy a EGR Block off plate ????
I remember that i saw some plates to block that silly hose that runs over the passenger valve cover...where can i get the plates for that ???? i dont remember where i saw them !!! what's that hose function ?????? im planning to delete all of them ! thanks Hose locations and EGR http://img247.imageshack.us/img247/9431/delete2he2.jpg Hose installed http://img224.imageshack.us/img224/3989/deleteky3.jpg |
I cut them out of 1/4'' aluminum plate. Not worth the time and money to buy them. :)
Originally Posted by Calderone
(Post 1566280532)
I remember that i saw some plates to block that silly hose that runs over the passenger valve cover...where can i get the plates for that ???? i dont remember where i saw them !!! what's that hose function ?????? im planning to delete all of them ! thanks Hose locations and EGR http://img247.imageshack.us/img247/9431/delete2he2.jpg Hose installed http://img224.imageshack.us/img224/3989/deleteky3.jpg http://cgi.ebay.com/ebaymotors/CHEVY...9486QQtcZphoto |
thanks but there is something missing here !
i can see 3 here : 1 - block off plate for : - COLD START INJECTOR (I DONT WANT THAT) - EGR - OK - EXHAUST CROSSOVER PLATE (ARE THEY 2 ???) I SEE 1 http://img267.imageshack.us/img267/2356/6bc41kh7.jpg I need only that...the complete kit looks cool do i need the cold start block off if i put edelbrock '89 runners ? |
(Post 1566280777)
i can see 3 here : 1 - block off plate for : - COLD START INJECTOR (I DONT WANT THAT) - EGR - OK - EXHAUST CROSSOVER PLATE (ARE THEY 2 ???) I SEE 1 http://img267.imageshack.us/img267/2356/6bc41kh7.jpg I need only that...the complete kit looks cool do i need the cold start block off if i put edelbrock '89 runners ? http://cgi.ebay.com/ebaymotors/CHEVY...0890QQtcZphoto |
Jon,the exhaust crossover needs 2 plates
i only see one plus the EGR one http://img247.imageshack.us/img247/9431/delete2he2.jpg |
(Post 1566280997)
i only see one plus the EGR one http://img247.imageshack.us/img247/9431/delete2he2.jpg but thats the place |
i just did it !!!
thanks ! i will be getting this,its a pita take off that silly hose everytime i want to take the valve cover off.- and i dont want the EGR valve anymore since maybe its not working properly,i dont know how all of this will affect my car but i think nothing terrible since this items are being bought all the time ! any idea on what could happen with no egr and crossover hose ? thanks |
I read somewhere that you need to delete the EGR function in your
PROM....I only skimmed it since I'm stuck with mine...:( |
Here's a cheap way.Cut the flanges off the old pipe and reuse with a couple of coins. The EGR valve you can just block with an aluminum plate,easy enough to fabricate.
http://i184.photobucket.com/albums/x.../condos035.jpg http://i184.photobucket.com/albums/x.../condos031.jpg |
thanks staugur
are the 2 ends of the crossover exhaust tube identical ? thanks |
(Post 1566285908)
thanks staugur
thanks !
TPIS sells some too. :yesnod:
what's the advantage on doing this?
Zero without something to keep your combustion temps under 1200 degrees which is what EGR does. Get above that combustion temp and it forms NOX - ok - so you're not a tree hugger - but you can also get detonation. The ECM then pulls timing and you lose performance (and maybe a mile or two per gallon - kinda of important these days). At worst, you wear out what may be an allready worn out motor. Anyway, unless you want to swap out the cam for a little more overlap - or maybe figure out how the Brits used water injection to keep their Spitfires flying - I'd fix it; it isn't that difficult to figure out. And while you're out it, spend your money on a Scanner or a cable for your laptop, which along with some free software, will give you all you need to monitor how everything is doing.
great post. love the forum
hi sammy, did mine on my 85 (only needs one plate) cleans up a lot of mess with hoses and pipes and mine had a vacuum block on the intake manifold that went too,
got my plate, which is cnc'd billet alloy for $15 off ebay. and no codes or ses light at all :thumbs: http://i395.photobucket.com/albums/p...d/P8160067.jpg |
thanks ! guys this is a 3 year old thread
i have now the accel base with non egr all blocked , keeps everything clean less things to worry , it's under the Super Ram now :) Thanks ! |
Originally Posted by staugur
(Post 1566285285)
http://i184.photobucket.com/albums/x.../condos035.jpg http://i184.photobucket.com/albums/x.../condos031.jpg That is half @$$'ed in my book, but hey your car, not mine. So whatever floats ones boat I suppose. I'd get the plates cleaner look/less chance of revisiting it later. |
