A&a
Andy has a really nice FI set using a Vortech set up says 550 rwhp
500 rwtq. Nice secure 8 rib set-up. On the fence big time here. Cam or just get the set up from Andy. |
Go to the C6 FI/Nitrous sections for all the answers you need, and no you don't need the 8 rib for 550rwhp. Go with Andy's stealth baby blower cam, headers and vortech and make 650rwhp.
If you haven't called Andy yet, I would reach out to him for answers to any questions. I have Andy's Vortech kit on my '06 C6 and I'm very happy with the car & increased power. :cheers:
Originally Posted by Keith N
(Post 1566646462)
plus he's tweeking it all the time. Fits very nice in the open space on the right side. Have you checked your #'s |
Set up from Andy, hands down! :yesnod:
Originally Posted by DitchTehFish
(Post 1566646789)
One Vararam that seals perfect and ASp underdrive pulley FOR SALE |
Originally Posted by Rock'n Blue 08
(Post 1566646922)
Just Pm'd him for an install!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!:cool:
I like the V3 s/c he has and he is first rate at what he does. I like the paxton's but the V3 is making me wait since the oil pan doesnt have to be tapped. I have to get one or the other though. You wont regret that shop.
I wouldnt bother with the cam. In the end smaller cams have earlier intake valve closing point and may make more low end for these applications. A smaller pulley solves the problem for power if you want more so why give up driveability. |
I'm pretty sure Tom Wong has installed a couple of these kits and tuned them. You could install, limp up to Tom's on Andys generic tune and get her running right..Good luck, but your still going to have to do the wide body to get some rubber under the back end..
(Post 1566646640)
Waiting to hear back again from Andy, Like the set up, Keeps the Hood
Honestly, I use to think tapping was that bad for the oil pan but its only took me an extra 15 minutes.. You already have the steering rack out of the way and the kit came with everything that you'll need to tap it with. Their drill bit will prevent the aluminum shreds from going into the oil pan. The only thing I can suggest for Andy is to package the 3/8 NPT tap with the kit. I had to run all over town to find it. Finally had to call a friend and he showed me where it was.
I was juggling with the idea of having to stock a 100 dollars a bottle of supercharger oil (thats how much Procharge costs, not sure how much Vortech) and having to order it every 3-5k miles. Of course you will have to change it religiously otherwise you will have a burnt up Supercharger that smokes due to bad bearings. In addition, you will have to access the drain plug of the supercharger (not as easy as the drain plug of the oil pan). Anyways, that was what I went through. So just weight the advantages of each and decide for yourself. |
I have andys V3, the drain line hangs down by the oil pan for easy acsses and the oil sells $25 per change with tax and shipping.
I also have A&A "BABY CAM" 214-228 and his stage two heads, I am very happy with this setup and his service is the best.:cheers: Now I just need a deal on some tires that will hookup:thumbs: |
Originally Posted by nwc6
(Post 1566649155)
So I guess this means you're done chasing the bolt on M6 record???:rofl:
Good luck with the Blower, I got a paxton on my 98. Be careful, boost can be addicting...:yesnod: |
Originally Posted by jbsblownc5
(Post 1566658062)
Good luck with the Blower, I got a paxton on my 98. Be careful, boost can be addicting...:yesnod: It's all in the sixty and then easy shift to second, Last time 1st was holding but it would break loose on the shift to second. Plus I made a change and it's a little stronger on the top end! I think I am not doing a hard enough burnout either. A little luck and 11.46 here we come and they will kick me off. The cut-off is 11.50 |
