TPI firing order
1 Attachment(s)
Is this firing order same on 88 TPI?
Attachment 48160138 I removed the distributor, distributor cap, spark plug wires and now I but them back together according to this picture and when I crank it nothing happens. Distributor rotor can be assembled only two ways because there is a pin inside the bottom drive gear? If the firing order is same on 88 TPI can it just be timing? Can a slightest turn of the distributor mess up ignition? Please help!:) |
Yes it is.
Originally Posted by CAJUN C4
(Post 1569398958)
Yes it is.
dist.
Are you sure its not 180 degrees off?
Find TDC #1 compression stroke position the rotor pointing at #1 cylinder or one tooth on the dizzy before . Should get you close enough to fire it up. You can also check your timing mark on the harmonic balancer should line up around zero on the tab. If you have pulled the dizzy you need to be sure that the rod it fits into look in the hole lines up with the bottom of dizzy, that drives the dizzy.
timing
The rod on the bottom of the dist. turns the oil pump. if you have any oil pressure at all while cranking and the dist. is sitting on the manifold, your problem is base timing.
1. the #1 cyl. rockers have to be loose, engine on #1 tdc 2. the rotor in the dist. points to #1 3. the timing mark on the harmonic dampener is at the pointer. 4. THE DISTRIBUTOR IS PLUGGED IN......HELLO! If any of the above is off, your timing chain could have jumped a tooth. |
Originally Posted by superspeeder
(Post 1569398828)
http://i638.photobucket.com/albums/u...ring_order.gif I removed the distributor, distributor cap, spark plug wires and now I but them back together according to this picture and when I crank it nothing happens. Distributor rotor can be assembled only two ways because there is a pin inside the bottom drive gear? If the firing order is same on 88 TPI can it just be timing? Can a slightest turn of the distributor mess up ignition? Please help!:) As mentioned, bring #1 piston to TDC and pull the distributor. To find TDC, remove the #1 plug and cover the hole with your thumb. Spin the engine until you feel compression and you see the timing mark on the crank damper align with the 0 degree mark on the metal tab. You will probably need to clean the tab and use some paint or chalk to mark the line on the damper. When you feel that, drop the distributor in so the contact on the rotor points to the #1 teminal on the cap and bolt the distributor down. Install the cap, #1 plug and the wire. Disconnect the tan/black wire leading to the distributor and start the engine. Set the timing with a timing light to 6 degrees BTDC or whatever timing value it says on the Emission Control Information Label. Then reconnect the tan/black wire. |
When I replaced the gear bottom of dizzy I noticed the harmoinc blancer had slipped, so you have to do both look at tab & TDC #1. Easy way to fine TDC is if you have a compression gague. TDC compression is absoult though no matter what is showing on timing tab.
If the outer ring of the balancer slips, it will be difficult to set timing with a timing light. Electronic timing control won't allow for too much of a variance beyond the initial setting of 6 degrees.
Even if you do get TDC from compression or watching the rocker arms on #1 cylinder, the timing mark on the balancer ring is still going to have to at the mark on the tab to get it right. |
(Post 1569398828)
http://i638.photobucket.com/albums/u...ring_order.gif I removed the distributor, distributor cap, spark plug wires and now I but them back together according to this picture and when I crank it nothing happens. Distributor rotor can be assembled only two ways because there is a pin inside the bottom drive gear? If the firing order is same on 88 TPI can it just be timing? Can a slightest turn of the distributor mess up ignition? Please help!:) Then time it with a light(est wire disconnected) to 6BTDC. Oh yeah....burn that diagram when you are done:lol: |
I managed to fire it up today. Idle was a bit rough, but I think I should wait until engine warms up and then set timing with timing light. I will do that day after tomorrow because my car is jacked up right now for lowering...
Anyway, thanks guys!!! |
(Post 1569398828)
(Post 1569398828)
See the picture: http://finnshark.com/gallery/images/10353.jpg |
(Post 1569411267)
Originally Posted by Kubs
(Post 1569411629)
This is how my dad taught me to count! 18436572 :lol:
