•• All Injectors on sale! (FAST, Siemens, DeatschWerks) •• HINSON Motorsports
All of our Fuel Injectors are on sale!
http://www.hinsonsupercars.com/Pics/...Comparison.jpg Most injectors will max out at 80% duty cycle and this is the accepted industry standard. After you install heads, cam, intake, your sucking in alot more air and your motor needs more fuel! Your injectors will be unpredictable when maxed out and you do not want to be running out of fuel at 6000+ rpm. If you have any questions about which injector size or accessories you may need, feel free to ask them in this thread. You can reach us at 205-267-6387 or seth@hinsonsupercars.com High Impedance FAST 33lb Injectors LS2 Part# 30332-8 DeatschWerks 35lb Injectors LS1 Part# 18U-01-0035-8 FAST 36lb Injectors LS1 Part# 303608 DeatschWerks 39lb Injectors LS1 Part# 18U-01-0039-8 FAST 39lb Injectors LS3/LS7 Part# 30397-8 Bosch 42lb Injectors LS1 Part# 0280155968 DeatschWerks 42lb Injectors LS1 Part# 18U-01-0042-8 DeatschWerks 42lb Injectors LS2 Part# 13U-00-0042-8 DeatschWerks 42lb Injectors LS3/LS7 Part# 16U-00-0042-8 FAST 46lb Injectors LS2 Part# 30462-8 DeatschWerks 50lb Injectors LS1 Part# 18U-01-0050-8 DeatschWerks 50lb Injectors LS2 Part# 17U-00-0050-8 DeatschWerks 50lb Injectors LS3/LS7 Part# 16U-00-0050-8 FAST 50lb Injectors LS3/LS7 Part# 30507-8 FAST 55lb Injectors LS1 Part# 305508 FAST 57lb Injectors LS2 Part# 30572-8 DeatschWerks 60lb Injectors LS1 Part# 18U-01-0060-8 DeatschWerks 60lb Injectors LS2 Part# 17U-00-0060-8 FAST 60lb Injectors LS1 Part# 306008 Siemens 60lb Injectors LS1 - EV1 Part# 107961 Siemens 60lb Injectors LS1 - EV6 Part# 108191 DeatschWerks 65lb Injectors LS3/LS7 Part# 16U-00-0065-8 FAST 65lb Injectors LS3/LS7 Part# 30657-8 DeatschWerks 72lb Injectors LS2 Part# 17U-00-0072-8 DeatschWerks 78lb Injectors LS1 Part# 18U-01-0078-8 Siemens 80lb Injectors LS1 - EV1 Part# 110324 Siemens 80lb Injectors LS1 - EV6 Part# 109991 FAST 85lb Injectors LS3/LS7 Part# 30857-8 DeatschWerks 88lb Injectors LS1 Part# 18U-01-0088-8 DeatschWerks 90lb LS3/LS7 Injectors Part# 16U-00-0090-8 DeatschWerks 95lb Injectors LS2 Part# 17U-00-0095-8 Low Impedance Lucas 120lb Injectors LS1 Bosch 160lb Injectors LS1 Fuel components you may need for your build Caspers Electronics Injector Adapter EV1 to EV6 Part# 109076 LS2/LS3/LS7 Car using an LS1 Injector Caspers Electronics Injector Adapter EV6 to EV1 Part# 109077 LS1 Car using an LS2/LS3/LS7 Injector FAST Injector Harness Adapters - EV1 to EV6 (8 Pack) LS2/LS3/LS7 Car using an LS1 Injector FAST Injector Harness Adapters - EV6 to EV1 (8 Pack) LS1 Car using an LS2/LS3/LS7 Injector FAST Fuel Injector Spacer Kit Makes an LS3/LS7 Injector have the same height as an LS2 Injector Katech Fuel Rail Spacer LS2 LS1 Injector in an LS2 Manifold and Fuel Rail |
ls2
pmed :D
Originally Posted by turbo2001
(Post 1570733325)
pmed :D
seth
hey seth thank's for the reply bud, ? these will simply install with no other part's needed. o'ring's, connectors, etc, and also how much hp will the 46 lbs injectors support? thanks again joe from jax you also have another pm :thumbs:
(Post 1570743416)
Originally Posted by HinsonSuperCars
(Post 1571883250)
Thanks for your orders!
Ive heard that the fast injectors need extra tuning for the LS applications because they are not programmed. Is this factual?
Originally Posted by theofel
(Post 1571884509)
I'm in need of 60 # or 65# injectors for 2008 LS3 supercharged application. Which ones are the correct ones? Will I need injector harness adapters?
Originally Posted by c6 batmobile
(Post 1571885451)
Thanks Seth |
Seth,
Have 2005 C6 looking for 42lb green top Ford Injectors, I have a Spin Fast Intake purchased from you. Do you have these injectors and how much or another suggestion. Thanks |
Originally Posted by silver05c6
(Post 1571892556)
Seth,
Have 2005 C6 looking for 42lb green top Ford Injectors, I have a Spin Fast Intake purchased from you. Do you have these injectors and how much or another suggestion. Thanks Thanks Seth |
Hey Seth, I'm looking into an injector upgrade to prep for upcoming mods. It seems like the 60lb injectors are the way to go as other NA LS2s are making the big numbers with that setup. Will I see a gain from just swapping the injectors, and which ones will I need?:cheers:
Edit: I have a FAST 92 with stock fuel rails, if that makes a difference. |
Originally Posted by Spectrel
(Post 1572373556)
Edit: I have a FAST 92 with stock fuel rails, if that makes a difference. Feel free to give me a call if you have any more questions. Thanks Seth 205-267-6387 |
Thanks, for answering all my questions, I have some thinking to do now!
(Post 1572421342)
great service, bought a set of fast 60 ls1's last week... as well as svo 42's a few months back from seth.
thanks |
Originally Posted by lrobe22
(Post 1572578291)
thanks |
I'm using 60# injectors with a BAP running 60 psi, I'm over 100% duty at 5800 rpms, what do you suggest for my ls2 402 supercharged 07 Vette?
Originally Posted by blackbird345
(Post 1572624083)
Seth |
Hi I have have an 07' ls2 that I am doing a ls3 heads,cam,intake swap to and was wondering what I need for injectors??? I was also wondering if the ls2/ls3 fuel rails are the same?? I WILL buy my injectors from you but need to know what to get. I am shooting for 480-500 whp n/a and 620-650whp with a 150 wet shot. thanks in advance
^^^scratch that, I just called you and ordered 50lb injectors. great guys very helpful and knowledgable.
