Replacing bulb for the side marker light
How do you replace the bulb on the red "oval" side marker light? It is probably easy, but it didn't seem obvious to me how you access this bulb. Also, what is the replacement bulb?
I'm trying to get my car to pass inspection. Thanks |
2 Attachment(s)
Take out the taillight nearest the marker you need to change. Reach inside and twist the lamp unit counter-clockwise. The bulb is a 194
Here's a pic that should help Attachment 48179976 Attachment 48179977 |
:iagree: with DeeGee. Not hard to do once you take the taillight out.
Thanks guys!
Do I need more description on the 194 bulb? Do I just walk into Auto Zone and say I need a 194 bulb and they know exactly what I need? Greg |
The zone should know what a 194 bulb is.
Originally Posted by Navy Blue
(Post 1571783800)
Thanks guys!
What about the front side marker lights. Any gouge on R&R light bulb?
Originally Posted by Jumper11
(Post 1577350143)
I know the bulb number, How do I get to it?
5 Attachment(s)
(Post 1577351064)
Document ID# 655625 2002 Chevrolet Corvette ________________________________________ Park/Turn Signal/Side Marker Lamp Replacement Removal Procedure Attachment 48179978 1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information. 2. Remove the front fascia lower closeout panel. Attachment 48179979 3. Release the brake caliper cooling duct from the front fascia, and position the duct aside. Attachment 48179980 4. Remove the front turn signal lamp bracket retaining spring from the lamp bracket. 5. Remove the lamp bracket retaining spring from the front fascia. 6. Remove the front turn signal lamp bracket retaining screws. Attachment 48179981 7. Disconnect the sockets from the lamp. Attachment 48179982 8. Remove the lamp, with the bracket, from the vehicle. 9. Remove the lamp to bracket retaining screws. 10. Remove the lamp from the bracket. Installation Procedure 1. Install the front park/turn signal and sidemarker lamp into position on the front turn signal lamp bracket. Notice Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems. 2. Install the front park/turn signal and sidemarker lamp to bracket retaining screws. Tighten Tighten the front park/turn signal and sidemarker lamp to bracket retaining screws to 2 N•m (18 lb in). 3. Install the sockets to the lamp. 4. Install the lamp, with the bracket, to the front fascia. 5. Align the lamp to the opening in the front fascia and hold the lamp firmly in place against the fascia, while installing the front turn signal lamp bracket retaining screws. Tighten Tighten the front turn signal lamp bracket retaining screws to 3 N•m (27 lb in). 6. Install the lamp bracket retaining spring to the front fascia. 7. Install the front turn signal lamp bracket retaining spring to the lamp bracket. 8. Position the brake caliper cooling duct to the front fascia and press the duct toward the fascia to secure. 9. Install the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers. |
Or
http://forums.corvetteforum.com/c5-g...gnal-bulb.html Scroll to #5 The marker light bulb is next to the turn signal bulb |
1 Attachment(s)
Originally Posted by Kevin Kuse
(Post 1577351247)
Or
http://forums.corvetteforum.com/c5-g...gnal-bulb.html Scroll to #5 The marker light bulb is next to the turn signal bulb Attachment 48179983 |
I guess, some would have to add a step involving wire cutters :rofl:
Or they could do it your way :thumbs: |
2003 Z06 rear side light installation
I'm trying to install a new rear side light on my 2003 Z06. I've got all the parts and have installed, in place, the rear self threading nut. I can't reach to front one to screw it down. Any help here?
Originally Posted by Joe The Whoa
(Post 1587349234)
Originally Posted by Bill Vett
(Post 1587349589)
Remove outer tail lights and reach in, or remove the license plate and plate holder and reach in. Deep socket also helps. Do not over tighten or you'll break the stud off.
Thanks, Bill, I'll give it a try. |
Good luck Joe :thumbs:
For the rear markers I reached up from under the car and changed them out. Wish I had seen this post first as I had just had the tail lights out to put new halo's in. Would have saved me some time.
(Post 1587352202)
(Post 1587411282)
That worked great, thanks for the tip!
Bill:thumbs: |
