1984 Electrical problem
I just had a new battery put in at Sears. Not long after, I am driving at night, when the car goes dead, but the headlights still work. Nothing happens when I turn the key, and I checked all the fuses. (except for 2 silver cased things in the fuse area.) I had to get a tow home. Any ideas?
Bob:crazy::crazy: |
Not sure where they are on an 84 but it could be a fusible link. Check the manual for their location. My guess is that it is unrelated to the new battery.
Automatic or 4-speed? I had a problem with my manual with the mat under the clutch pedal and not allowing the clutch to fully depress. Now I always check my floor mat to make sure it's not shoved forward.
Originally Posted by avgjoe
(Post 1571954921)
Jack up the car and follow the wires from the starter. You'll find the fusable link in a thick red wire. It'll go up the fire wall, across it and over the the drivers side. Keep following it and you should find an inline plug (somewhere around or under the brake booster). This plug could have come apart. |
Yes, I guess I should be able to trace the line, off the starter. I never heard of a single, fusable link before. (mine is an automatic) I wonder if this happened, because I was trying to reinvent the wheel, with my headlight motors. I could not figure out the wiring/relay system, but I did notice that the headlight motors work on DC voltage. So I ran a pair of wires from the relay, to inside the drivers side. My plan was to rig a switch, so I could simply reverse polarity, by flipping a switch, and the motors would go the other way. I drove the car, before the switch was wired, and they probably toughed together. Now they don't work at all. I will probably need a new relay. I hate electrical problems!
I was under my 84 corvette, saw the red wire, or wires, at the starter motor. I saw 2 things that looked like they might contain fuses, (as you might find on an auto radio) but they were one piece, and appear solid. Are those the links?
Bob |
the fusable links are about 8 to 10 inches up from the starter on the starter wireharness. It is where the three red wires tie into one.
Thats great! Thank you very much. Should I just get rid oif them?
Bob |
Originally Posted by spectraluma
(Post 1572030774)
Bob |
Just the info I needed. I saw what must be a pair of these fuses, right near the starter, and on one of them, the wire was aged, and basically disconnected. My car is not raised up, right now, and it was hard to tell, exactly where it came from, but I have an idea, and when I raise the car, I believe I know where it goes.
Thank you very much! Bob |
Is the fusable link, a resetting thing? I appears that way, in my case. The red wire, off the fusable link, had broken off. I cleaned it, and ran a 10 gauge, teflon wire, directly to the battery. When I did that, power returned to everything, and it ran. After a minute, I smelled smoke, and saw it around the heater/defroster fan. Looking closely, it looks as though it was coming from a relay, below it. The car shut down by itself, but I was able to get power back, after a little fiddling. Any thoughts?
Bob |
