Gauges flicker and car won't start SOS SOS
When i turn the key in my 97 C5 the gauge lights flicker on and off very quickly- i can hear a relay clicking rapidly (like a hazard light relay) and she won't crank. The instruments don't cycle as they normally do.
After two or three times, it cycles normally and starts. Suggestions?? I hate electrical gremlins!! :banghead::banghead::smash: |
Bad connection somewhere
Check the battery. Mine did all of the above (except actually start) when the battery finally died. All it took was a really hot day and it was dead, no warning signs.
If the battery and its connections turn out to be good I would check the grounds and the internal ignition switch contacts.
My battery was going south when that happened too. The clicking came from the passenger foot well fuse/relay center, and my gauges flickered really fast, and the DIC wouldn't come up or was blank. I got a battery tender because of our harsh winters, and for the added sound system I installed in the car.
Just checked. Batt connections are solid- HOWEVER----I have had to jump it when i lift my ipod adapter on for a week without driving her. Did replacing the Batt fix the problem? The clicking IS in the pass footwell and the DIC does the exact same thing.
Check your battery with a meter across it. You should see 12.5 volts static with the ignition turned off. If less than that, check the battery connections as well as the solenoid connections which is where the alternator, battery and starter all come together. Do not forget that its electrically hot down there.
mine does this too... if i flip the key over it usually starts lol... sumthin with the pass key pellet not reading correctly. i thought it was the battery at first as well, however it was replaced in aug 09 and tested fine on the meter
Classic dead battery symptoms. The relay is chattering as you try to start with a low charge.
If you know why it died (Ipod) the next question is whether its an AGM battery? Is it a post 01 OEM or a Red Top? If so you may have killed it. If its a regular lead acid it may recharge. A jump start or a short run won't recharge it. You'll need an overnight charge or a new battery. Unlikely to be the VATS system as there would be a constant security light if the PCM didn't read the resistor. If the car isn't a daily driver its worth investing in a battery tender. |
Well let's see... if I came home and opened the front door and flipped my light switch and nothing happened, I would think it was the light, switch, bulb or fuse. But if I walked in the house and ALL my lights flickered, I think my first diagnosis would be the power source.
My bet is the battery. Also, if you have an AGM battery (like an Optima Red Top) and it went dead (as you mentioned) - they usually cannot be fully resurrected. |
Originally Posted by 8VETTE7
(Post 1572659245)
Battery!
(Post 1572659245)
Battery!
Why do you guys continually over analyze the obvious?:willy: |
Originally Posted by 97C5owner
(Post 1572656365)
Originally Posted by Choreo
(Post 1572658257)
Happens all the time. :lol: If you hop in the car, turn the key and it chatters or cranks slow you start your troubleshooting with the battery. :yesnod: You don't check the air in the tires..... |
Originally Posted by Blue 92
(Post 1572665333)
Water heater. :yesnod:
Happens all the time. :lol: If you hop in the car, turn the key and it chatters or cranks slow you start your troubleshooting with the battery. :yesnod: You don't check the air in the tires..... The car even did it with the battery fresh off the charger. Turned key from run to off a couple of times and the gauges finally lit up and went thru their self test cycle. Fired right up. Starter didn't drag at all. Wasn't slow to start. It is a lead acid battery. :lurk: |
:lurk:
(Post 1572670640)
... Batt tests good after I charged it. Been tested 3x this week now. Good every time.
The car even did it with the battery fresh off the charger. Turned key from run to off a couple of times and the gauges finally lit up and went thru their self test cycle. Fired right up. Starter didn't drag at all. Wasn't slow to start. It is a lead acid battery. :lurk: Bill Curlee has a great post on locating and checking ground points here: http://forums.corvetteforum.com/c5-t...o_threadsearch |
I'm almost Positive it's your IGNITION SWITCH!
The contacts have become Dirty, and is not allow a full contact. I had this same problem, and the same symptoms your describing. I did the Fix following Bill Curlee's Advice, and everything has been good for some time now. The Fix looks more Complicated than it is. Took me about 2 hours. Here is the Fix http://forums.corvetteforum.com/c5-t...ch-repair.html |
(Post 1572670640)
Thats the thing. When the gauges cycle over correctly, it fires right up. No hesitation. Batt tests good after I charged it. Been tested 3x this week now. Good every time.
(Post 1572678487)
Did you have it load tested?
Sounds like a bad connection. The C5 is ground sensitive and there are more grounding points than you would think. :yesnod: Bill Curlee has a great post on locating and checking ground points here: http://forums.corvetteforum.com/c5-t...o_threadsearch
Originally Posted by slvrzo6
(Post 1572678650)
The contacts have become Dirty, and is not allow a full contact. I had this same problem, and the same symptoms your describing. I did the Fix following Bill Curlee's Advice, and everything has been good for some time now. The Fix looks more Complicated than it is. Took me about 2 hours. Here is the Fix http://forums.corvetteforum.com/c5-t...ch-repair.html Great info on grounds and switches but eliminate the battery before you dive into this pit! Don't ask me how I know,,,,unless you need to,,,,and then I will help all I can! If the battery change doesn't hook you up, send me a pm! p.s. Doesn't matter how old your battery is. Even new ones fail from time to time! |
