Towing with a Tow Dolly???
Anyone have any experience towing a C3 (auto) with a Tow Dolly?
thanks! |
Not specifically with a C3, but I'd either pick it up by the rear or remove the driveshaft. Without the engine running there's a risk there won't be enough circulation in the trans to guarantee you won't burn up something in neutral. Learned from having seen this happen more than once to others towing vehicles behind their motorcoaches.
:cheers: |
Haven't towed a C3 with one but the 2 times I did tow with one told me to never do it again
If you don't disconnect the driveshaft, you will almost certainly burn up the trans. The pump is driven by the engine, so with the engine off there is no trans fluid circulation.
Why don't you just rent a U-haul trailer for $50. You won't have to worry about anything.
I did it about 3 years ago... and now I see maybe i shouldn't have...
I took mine 15 miles on stop and go roads (very slowly) from the place where the brake cliper locked down on the disk to home. I put the front on the dolly and did not disconnect the drive shaft. I hate my auto trans anyway, but it seems to be working as well as it was before I towed it. |
Originally Posted by jordan89
(Post 1573654658)
AND the U haul trailers work really well for the C3's. Just make sure you tell them what you are towing so they will give you the correct trailer. |
Originally Posted by mikejpss
(Post 1573657900)
:iagree::D:iagree:
AND the U haul trailers work really well for the C3's. Just make sure you tell them what you are towing so they will give you the correct trailer. These cars are pretty heavy, mine is 3690# added to the trailer weight of 2200# puts it over 5000#. A class III hitch is rated for 5000# and allot of pickups aren't rated for that weight (even though they'll probably pull it OK) I believe U Haul does have an aluminium trailer that weighs less but i don't know how much. |
I wouldn't go too far with a tow dolly unless I had a large tow vehicle. The tow dolly with a car on it behind a pickup can push the rear of the tow vehicle sideways on a corner and loss of control is easy. I would recommend using a trailer with brakes on all wheels.
Get a uhaul car trailer way better than a dolly about a hundred bucks a day
I once towed my 82 vette on a dolly behind my 84 trans am for about 60 miles. No side effects from nothing being disconnected and the car towed great on the dolly. If longer then a 100 miles, then I would take the driveshaft out
1 Attachment(s)
U-Haul wont rent you a trailer if your tow vehicle is not within their requirements for what you are going to tow.
Attachment 48180446 If the 4 Runner had been 2 wheel drive it would not have qualified. (tow vehicle weight) |
I just wouldn't recommend for anyone to use a tow dolly unless they have a "heavy" tow vehicle. I also wouldn't recommend towing a corvette with one.
Also, In my state, the tow dolly doesn't need to be licensed or insured, but the towed vehicle has to be insured and licensed if the wheels are on the ground. Might want to check on that too if you decide to use a tow dolly. |
If you tow with a dolly, from the front, dont even attempt it unless your steering locks, otherwise your wheels will try to turn when going around corners and the tires wont straighten back out again after you come out of the corner... Trust me I know, we had to pull over about 8 times and straighten the front tires back out on the way to the muffler shop..
FD |
I would only use a tow dolly if all other options were exhausted.....As mentioned by others -- Tie-off steering to seat frame, remove driveshaft .......
Although most agree that a tow dolly is just "wrong", I would have to disagree with the tying off or locking the steering wheel. Although the wheel plates swivel on the dolly (mine does), the wheels should be free to turn too. I would suggest that the wheel harnesses are not tight enough if the wheels turn in them. You want the towed vehicle to follow and trail. If the steering is locked, you could tweek the tow dolly, but more likely put a lot of extra force on your steering and suspension system and possibly tweeking it. I usually get the wheel harnesses as tight as I can by hand, and then give it another shot with my foot. Make sure the tires are nice and hard on the towed vehicle too. Adding a little air to the harnessed wheels can also help tighten up the wheel harness.
I always; 1. take a battery powered air compressor and inflate the tires to their max psi. 2. tighten the wheel harnesses with my foot. 3. check harnesses after 5-10 miles. 4. use safety chains (they saved me once). 5. leave the steering unlocked. 6. make wide turns. 7. never back the dolly up with a vehicle on it. 8. always use a heavy towing vehicle. 9. never tow a Corvette with a tow dolly. |
Originally Posted by builder
(Post 1573692392)
Here is a tow dolly manual link, which clearly states the steering should be locked. Here is a quote from the manual Place the ignition switch in the steering wheel to the locked position and make sure that the front wheels are pointing straight ahead. Assure that steering wheel is locked and will not turn. (Parking brake is to be released after tie down procedure is completed.) On vehicles not equipped with a steering wheel lock mechanism is imperative that the steering wheel be immobilized by tying it to the seat frame or other suitable point with a ratchet strap or other device. FD |
I stand corrected. I have not had much problems although I only use a tow dolly within 15 miles, but......refer to item #9 on my list.
9. never tow a Corvette with a tow dolly. That's not in the manual. |
(Post 1573694633)
9. never tow a Corvette with a tow dolly. FD |
I agree with don't tow it with a dolly. Years back I towed my 80 from Houston to Atlanta on a dolly since the vehicle I had at the time wasn't approved by uhaul for a trailer. Once the car was on the dolly it towed OK unless of course you needed to back up in any form or fashion. The huge problem I had with it is I had to pick the car up and slide the dolly under it. The nose is too long and low to drive the car onto the dolly. It was about as much fun getting it back off the dolly and I yanked the clip that holds the air dam in place off in the process. I would not recommend it as a whole for sure.
