Ignition switch removal
What's the trick? I'd imagine the tumbler has to come out but how? I want to replace the bezel but can't get the switch apart?
Thanks |
Originally Posted by inmyblood
(Post 1573953291)
what's the trick? I'd imagine the tumbler has to come out but how? I want to replace the bezel but can't get the switch apart?
Thanks |
you are suppose to turn it all the way to the left past off. then put a paper clip or wire in the hole and press a small brass button. then turn
the key left some more. it then pulls out. however my 63 had two holes and would not go past off. the brass ball is on the rim next to the lock mech. i had to get jungle with mine. it finally pulled just the outer trim off. then i pressed the brass ball. i was lucky my napa dealer which never has any stock had the switch and lock mech for a 63. just did this friday when smoke started coming out of my speaker area. switch started to melt the black plastic wiring harness on the back. jim |
Originally Posted by wombvette
(Post 1573953414)
un-humm what year?
58.......... |
Originally Posted by jdk971
(Post 1573953524)
the key left some more. it then pulls out. however my 63 had two holes and would not go past off. the brass ball is on the rim next to the lock mech. i had to get jungle with mine. it finally pulled just the outer trim off. then i pressed the brass ball. i was lucky my napa dealer which never has any stock had the switch and lock mech for a 63. just did this friday when smoke started coming out of my speaker area. switch started to melt the black plastic wiring harness on the back. jim Thanks I'll look for the hole. Don't remember it but will look again. |
Originally Posted by INMYBLOOD
(Post 1573953705)
Originally Posted by firstgear
(Post 1573955650)
Just in case you haven't, I'd recommend disconnecting the battery before working with either the headlamp or ignition switch . . . . . .:ack:
There should be a small hole in the face of the switch. Insert a paper clip n that hole and with the key in the switch turn it to the left {accessory position} and it should come apart. To put it back together reverse the procedure....I use to do it for customers all the time and I think the above is the correct way.
sorry, another reply had it right that I missed |
(Post 1573953705)
PS Don't think there is an accessory (ACC) position on a '58 .... I know there isn't one on my '61.. |
Originally Posted by Frankie the Fink
(Post 1573959295)
I am showing unnatural self restraint in not going after this one...at least a 1/2 dozen punch lines come to mind....
(Post 1573964523)
Thanks Frankie we knew you were a man of restraint!:cheers: Most women I meet are in the lock position. :ack:
a paper clip ain't going to help you then |
Originally Posted by Steve59
(Post 1573969588)
(Post 1573969735)
But a money clip might:thumbs:
believe it or not both parts, switch and tumbler, came to just under
60 bucks last friday. jim |
