HELP Locked my keys in the car
Hi Guys.
Today being a nice day so I thought Id drive the Z06 to work. Open the trunk with the fob, threw so stuff in and closed it. And I think the keys also went in the trunk.. So I didnt drive the Vette today, Its sitting at home with the Keys in the trunk. So does Anyone have Any idea's??? Dale M |
Same thing happened to me, I ended up going to the chevy house and getting a spare key made.
Obviously you don't have a spare fob sitting around. :willy: Might have to get a spare key made from a dealer - not sure if a locksmith can do it without a key to use as a pattern.
Right from the owner's manual.
"One key is used for the ignition, the driver’s door and all other locks. When a new vehicle is delivered, the dealer gives the first owner a key and a bar coded tag. Both the key and the tag are attached to a key ring. The paper tag has a code on it that tells your dealer or a qualified locksmith how to make an extra key. Keep the bar-coded tag in a safe place. If you lose your key, you’ll be able to have a new one made easily using this tag. If your key doesn’t have a tag and you need a new ignition key, go to your dealer for the correct key code. Notice: If you ever lock your keys in your vehicle, you may have to damage the vehicle to get in. Be sure you have spare keys." |
i cant stress how easy it is to slip a metal clothes hangar between the window seal and the window to press the unlock button. it takes less than a minute. the alarm will go off.
Originally Posted by SaberD
(Post 1574620428)
what about that....shaking the car thing if the fob is in it ?
If you go to a dealer or locksmith you will need ID and the owners card. They just don't make keys and give them to anyone. Having the vin # alone most places will not make a key.
(Post 1574620428)
ive done this at least 3 times since i have owned the vette |
Originally Posted by 04 commemorative
(Post 1574620683)
Originally Posted by Bill Vett
(Post 1574620808)
only if the fob has a passive setting, 97 to 99. I locked my keys in my 93 and that worked. Not so lucky in my 00, pulled the glass out and stick a dowel in to hold the window, hanger to filp the door lock button. Just make sure you don't have a sharp edge on the hanger or you'll scratch the door panel.
I've done this twice unfortunately. First at Lowes where I had to go back in the store to buy a thin rod so's I can break into my own car :rolleyes: and the second time was at a pressure wash where a buddy grabbed a coat hanger for me.
After having done this twice now, I'm pretty nervouse about the security of my own Z :willy: I mean the alarm goes off and everything and I park her in the garage when at home, but.... |
My wife did that once with my convertible. She called me all in panic because she was worried it was going to rain and the top was down. :willy:
Did I mention she is blonde ? :rofl: :rofl: Doug |
That sux ,been there!!:thumbs:
(Post 1574620683)
(Post 1574620808)
Originally Posted by BLK RED
(Post 1574621929)
Knock on wood but I haven't locked the keys in any car since the 80's!
Originally Posted by jrose7004
(Post 1574623750)
Originally Posted by LS3x416
(Post 1574624280)
What are the 80's?
