"widest" 285/40/17s???
Tire widths seem to vary between manufacturer. I've noticed that Sumitomo brand tires tend to run narrower (have heard the same thing about Nitto).
So what brand tends to be generally "wider"? (looking for 285/40/17 specifically) Thx! |
Originally Posted by jon1all
(Post 1575676665)
So what brand tends to be generally "wider"? (looking for 285/40/17 specifically) Thx! should be 285 millimeter wide 40 means the height is 40% of the with and 17 is the wheel size |
Originally Posted by ch@0s
(Post 1575678507)
I never heard that.. makes no sense really.
should be 285 millimeter wide 40 means the height is 40% of the with and 17 is the wheel size But in reality, the "actual" width does indeed vary. Here is a post with pictures showing the difference in a 315/35-17 tire. http://forums.corvetteforum.com/1564099378-post1.html |
[QUOTE=RollaMo-LT4;1575678609]Yep, what you say is all true.
But in reality, the "actual" width does indeed vary. Here is a post with pictures showing the difference in a 315/35-17 tire. [url] Yup. Doesn't seem right but seems to be the case. After doing some more digging it seems Goodyears tend to run on the wide side. Anyone have any experience with Kumho in this regard? Tend toward wider? Narrower? |
I bought two different motorcycle tires, Metzler 260/40 18 and Avon 250/40 18. The 250 is wider than the 260.
Manufacturers tend to have close, but different measuring points. I measured the tread surface. |
Here is what I found from TireRack.com
285-40-17 Continental "ExtremeContact" 11.4" Kumho Ecsta XS 11.0" Goodyear Eagle F1 GS-DS 11.3" Pirelli PZero System 11.5" Bridgestone Expedia S-01 11.7" Goodyear Eagle GS-C EMT 11.4" Kumho Ecsta SPT 11.5" Kumho Ecsta ASX 11.5" Michelin Pilot Sport A/S+ 11.4" Bridgestone is the widest at 11.7" and Kumho is the smallest at 11.0" |
[quote=jon1all;1575679831]
Originally Posted by RollaMo-LT4
(Post 1575678609)
Hope someone can answer this quick! I can get a pretty good deal on some 235/40zr17-94w to go on my '89. Can I put these on the stock rim and/or any modifications needed (spacers, etc.)??
235 is going to be a pretty narrow tire regardless... might want to rethink that size, good deal or not.
I wondered the same thing too as I have had the same size tires as another guy and they lhis always looked wider than mine. Hmm
Does anyone know which tire is wider between the MT and the nitto drag radials?315 35 17
Here is your click back: http://social-media.co.uk/images/pay...t-services.jpg |
Originally Posted by lushdrunk
(Post 1575680519)
Originally Posted by twin540
(Post 1575689249)
So my guess is the MTs will be wider (not to mention they hook wayyyyyy better) :thumbs: |
Goodyear and BFG
You always get wide with BFG and Goodyear.
this is a 285 Goodyear F1-GSD3 and a Michelin 285. http://i886.photobucket.com/albums/a...jpg?1287842473 http://i886.photobucket.com/albums/a...jpg?1287842473 |
Great comparison pic... thanks for posting that! Just wish those Goodyears weren't so dang pricey!!! Love that tread!!!
Originally Posted by project C4
(Post 1575707735)
this is a 285 Goodyear F1-GSD3 and a Michelin 285. Is this the new metric for measuring tires? How wide they look? I can't believe someone asked which drag radial looked wider. Wouldn't you care more about which hooked better? :willy: |
Originally Posted by Aurora40
(Post 1575707970)
Doesn't exactly seem a fair comparison, as the Goodyear is not mounted. Put it on a 9.5" rim, and it will pull in.
The goodyear might pull in some but not much. I looked at these pretty closely when I was comparing and thought about the one being on the rim and not the other. I measured and the tread patch alone is more than an inch wider on the Goodyear. :thumbs: |
(Post 1575676665)
