Best tool for cutting exhaust pipe while still attached to car?
I figure an exhaust pipe cutter won't work since I won't be able to get all the way around the pipe at the top where it's closest to the car's floor (right?).
Torch is no good since I would likely hurt myself or the car. So a reciprocating saw is my only option... right? |
maybe a grinder with a big cut off wheel?
i use a pneumatic 3" grinder and it works well. basically all you need to do is work the sides of the pipe and you can then get across the top without a problem. the 3" is small enough to be able to get into tighter spaces so it works well.
Sawzall
Originally Posted by dougbfresh
(Post 1576145097)
Sawzall
sawzall or something like it.
or, go to exhaust shop. |
(Post 1576145097)
Sawzall
I used a chain type cutter when I installed my x-pipe.
Plenty of room ... worked like a charm http://cdn.dealsdirect.net/m/product...46_600x600.jpg |
Originally Posted by wcsinx
(Post 1576145446)
Plenty of room ... worked like a charm Thanks all for the responses :flag: |
I second the "chain type" pipe cutter. I just did a Corsa X-Pipe and Corsa Indy Pace Car mufflers. Without this tool it would have been much more difficult. If you have an "Oreilly Auto Parts or similar store, check their "tool loaner" program. I borrowed the tool...brand new never used for a small deposit! Worked great!
Originally Posted by skyavonee
(Post 1576145604)
Excellent! This is exactly what I wanted to use but was afraid wouldn't be able to get around the top of the pipe. I'm installing a Borla X-pipe, hopefully this weekend.
(Post 1576145446)
Chain cutter is the correct tool. They work great. Just be sure to oil it well when you're cutting. They don't work well when dry.
(Post 1576144993)
Originally Posted by Bills03Coupe
(Post 1576146285)
This is definitely the way to go. Makes a clean cut, without any jagged edges. Very little clearance is needed to swing the chain over the pipe.
I've used all of the methods suggested and the chain cutter is the best in my opinion. It's hard to get a perfectly straight cut with a sawzall and the pipes can bounce causing the blade to bind.
(Post 1576145446)
(Post 1576145097)
Sawzall
(Post 1576145446)
I went to Autozone - they rent tools like the chain cutter and pipe expander. They run you credit card for the cost of the tool and when you return it they credit it all back to your card. Hard to beat Free.
I needed the pipe expander to get my X pipe on. |
