is the multifunction switch, headlight switch and turn signal switch the same thing
im searching part #26075870 for a multifunction switch
but each brand has it labeled as something else? does the multifunction switch come with a new turn signal lever |
Originally Posted by luckyirishguy
(Post 1577056746)
but each brand has it labeled as something else? does the multifunction switch come with a new turn signal lever Not that difficult to swap out either. Check out: Rockauto.com gmpartseast.com amazon.com big auction site dot com Compare prices. Don't be afraid of Delco (D1573E) either if you find pricing you like. HTH |
:yesnod: Check out gmpartshouse.com also.
yes, not too difficult to replace...good luck!
thanks
Originally Posted by oakvillec5
(Post 1577058142)
