Synthetic oil smoke?
Does synthetic oil smoke like dino oil. I heard a rumor it does not ??
Yes.
Olive oil doesn't smoke till 450F...........I use this
http://ecx.images-amazon.com/images/...9L._SS500_.jpg |
I like extra virgins.
Originally Posted by Mike Ward
(Post 1577618315)
Originally Posted by birdsmith
(Post 1577617868)
Yes.
Originally Posted by BPHORSEGUY
(Post 1577617766)
I've had customers in with Mobile 1 that showed no oil on the dipstick,engine had no major leaks and the customer said they never saw any smoke. It made sense the rumor was true. |
(Post 1577617766)
Believe me, it does smoke. My dad has a 90 ZR-1 and those early 90-92 motors were designed without valve stem seals. So they will smoke some on start up and hard accelerations. The later year, 93-95, motors had valve seals to eliminate this. All my dad's motor has ever seen has been Mobil 1 both by him and the previous owner. It smokes and after a while of not washing it, the back end gets black.
Originally Posted by roscobbc
(Post 1577618854)
Ah, yes - are they are the ones that often look like the rear end of a London Transport double decker bus ?
Even if some of them smoke. |
(Post 1577621216)
Do you want to think about it?:eek:
(Post 1577625931)
OK,OK...I honestly couldn't tell you if synthetic smokes more than mineral oil or not. I only put it my own street-driven cars once when I bought a case of Valvoline synthetic and split it between wifey's Isuzu Rodeo and my Ford Ranger. The Isuzu had never used oil before in any noticeable amount but within 2000 miles of putting the synthetic in it the oil light came on and when I checked it there wasn't any showing on the dip stick. It never did visibly smoke or do anything else to indicate that it was using oil excessively and I was never able to figure out where it disappeared to. I understand that synthetic typically has better thermal properties than dino oil, i.e., it doesn't break down below 300 degrees, but I don't know if that would make it smoke more or less than conventional oil. Hope this doesn't add to the confusion too much, and I hope everybody gets those extra virgins!
Your first post seems to indicate your saying YES it smokes but your 2nd post seems to align with my experience = The oil in the engine disappeared with no apparent smoke and no leaks. |
(Post 1577624657)
That's the ones. Imagine a double decker bus full of extra virgins. You can never have too many extra virgins. :rofl: Even if some of them smoke.
Originally Posted by ...Roger...
(Post 1577626979)
Now your confusing me. Are you saying synthetic smokes or doesn't smoke ?
Oh those combustion temps will make any oil smoke alright.
From my experience, Synthetic oil smokes just like dino oil. My daughter is driving my '93 GMC pickup. I bought it new and have used Mobil 1 from the beginning. On the way home from picking it up, I had the oil changed to Mobil 1 with just 22 miles on the odometer. This is contrary to what many say on the forum that you can't break-in an engine on synthetic. Well, the engine now has 198,00 miles on it. It's begun smoking just on startup, so the valve seals have finally given up. I checked compression on all cylinders and they're all right around 160 so the rings are OK. By the way, it's a good ole 350. It's puff of smoke on startup looks just like any oil smoke from an engine that needs new seals.
Duane |
(Post 1577627286)
What I'm saying is I'm not really sure...but (apparently like yourself) I have experienced mysterious synthetic oil disappearance syndrome and not seen any smoke to indicate that I was burning oil. In my first post I was admittedly being a bit of a smart arse. With the kind of consumption that I was seeing (3 quarts in 2000 miles) there should have been huge billowing clouds of blue smoke but there wasn't...so I suppose it's quite likely that synthetic oil doesn't smoke as much as mineral oil, extra virgins notwithstanding.
please do tell... thx...p |
Originally Posted by pauldana
(Post 1577637693)
How did you fix the "mysterious synthetic oil disappearance syndrome"
(Post 1577639130)
I did the logical thing...stopped using synthetic oil!
I have read some of these seemingly endless threads regarding synthetic vs. mineral oil and they always degenerate into an endless (and pointless IMHO) argument. I DO know this...that when I ran 1 batch of Valvoline synthetic in wifey's Rodeo it used 3 quarts of it in 2000 miles, and when I switched back to mineral oil it stopped doing that. I'm sure that before this baby peters out some chemical engineering whiz kid will appear with a sophisticated-sounding explanation. I personally don't know why our car consumed the stuff so voraciously but as it turned out the solution was certainly simple enough. I did use 15-50 Mobil 1 in my vintage racer with good results for 3 years, reason being that synth is well known (to my satisfaction anyway) for resisting high temperatures and here in SoCal we tended to do a lot of racing in hot locales in the summer. For a street-driven car I just can't justify the added expense of synthetic. The whole ZDDP issue is really beginning to rear its ugly head though...this debate will probably never end.
