Drivers side heated seat not working at all.
I recently had my seats reupholstered to the 3lz dark titanium pattern on my 06 Z06. I now have found that the drivers side heated seat does not function at all. Now lets get the Florida jokes out of the way here: ...................... Back on topic: I have searched, and I checked in the fuse box by the passenger foot well, I pulled all 3 fuses, the 1 relay and the separate passenger and driver fuses in the box off to the right of the main fuses, and I found that everything appeared to be in fine condition, nothing blown. The passenger heated seat is working great. When I press the button for the driver side, nothing happens, the lights do not even attempt to come on. Ive also checked under the seat, Ive unplugged and replugged in all the wiring harnesses and still nothing. I know it was working fine before the seats were redone...any thoughts?? Has anyone experience this issue? Thanks.
EDIT: Ive also tried pushing the button on the drivers side once or twice and felt the seat but it did not appear to warm up. I don't know what reupholstering a seat would break the heater component....frustrating. EDIT 2: Upon further inspection, it appears the the drivers side and passenger side heated seat fuses are the green 20A kind and the illustration shows there should be only a 15A blue fuse there, don't know if that matters...like I said it was all working before, now its not. |
I had the exact same problem with mine. It turned out to be a wire rubbing on part of the seat frame, underneath. It rubbed the insulation off the wire and shorted out. :cheers:
I looked under my seat, all wires look fine, I do have a wiring harness not plugged in underneath, I had the seat out of the car last week and could not find where it went....it's white and square shaped.
My passenger side did that after the dealership changed my sticking door on the ashtray...Before I bought the car the previous owner went to the dealeship to fix the door for me....About a month later I pushed the button and nothing. So I checked the pushbutton on the console and low and behold the connector in back was disconnected. Those clowns at the dealership must have done it :toetap:....Connect it back up and bingo she works like a charm.
Originally Posted by forg0tmypen
(Post 1577622901)
Like I said I looked under the seat but I'll be damned if there wasn't a spot to plug it into...what's the heated seat harness look like anyways?
Take it back to where you had the seats done...why the heck should you try to figure it out if they broke it.
Originally Posted by Garret
(Post 1577625433)
There is a flat, white Molex plug that needs to be plugged in under the seat. That's the seat heater wiring.
I would agree with taking it to who did the work on your vehicle. It would seem to me that they missed something when putting the seat back in.
Good luck with your repairs, Brent GM Customer Service |
