Thanks for the update.
Maybe run it by Leno's garage when your done? Your project is more interesting than some of the feature cars that show up there. |
Originally Posted by Churchkey
(Post 1581119384)
Maybe run it by Leno's garage when your done? Your project is more interesting than some of the feature cars that show up there. MO |
Hi folks,
Those who have been following my build, I have been slowly gathering the batteries and adding them, I'm at 13 out of 18, there should be 4 more arriving at the end of the month. I just purchased the BMS ( battery management system which monitors all the cells. I have 5 batteries to go to finish the build. I took the car out for a 12.5 mile drive and used 33Ah of battery. This seems a bit high, but I managed to hit EVERY light on the way. At 50 mph I'm averaging about 60 amps draw on the pack ( which is 200 ah) So even with 5 batteries short I can still hit 60 miles range. Once finished I should be at about 325 hp and 700 ft/lbs of torque at 0-2800 RPM Still some wiring I need to tidy up, on the BMS the showed the wrong plug locations ( the illustration showed the bottom view versus from the top, why I have no clue)so I need to go back shorten some wires up. https://cimg2.ibsrv.net/gimg/www.cor...39874ef6ae.jpg Rear pack being fitted into the car. https://cimg2.ibsrv.net/gimg/www.cor...28647b2e4b.jpg Front pack installed. (I'm working on the box for this.) https://cimg5.ibsrv.net/gimg/www.cor...f92ba6fe1d.jpg View of under the hood https://cimg1.ibsrv.net/gimg/www.cor...ca06e5fb29.jpg Wired and installing BMS wire taps https://cimg3.ibsrv.net/gimg/www.cor...f5e401aa05.jpg Punch list for the BMS https://cimg7.ibsrv.net/gimg/www.cor...b4cebfced3.jpg Laying out the BMS and connections, it only comes with 6' lengths so it required adding longer lengths to reach the batteries. https://cimg1.ibsrv.net/gimg/www.cor...b4d9c9ceeb.jpg Rear Pack buttoned up. https://cimg8.ibsrv.net/gimg/www.cor...61dcfac1fa.jpg Inside view, the plan is to seal the front up with clear lexan. https://cimg3.ibsrv.net/gimg/www.cor...b759c0ef3d.jpg BMS wired ( wiring needs to be tidied up the instructions showed the top connector at the bottom thus longer wires :(.) Enjoy... MO |
:rock:
Great work continued! I like you're not just settling for having made it electric to begin with and continue to work and improve it.
Originally Posted by Mo_Bandy
(Post 1581646362)
Hi folks,
Those who have been following my build, I have been slowly gathering the batteries and adding them, I'm at 13 out of 18, there should be 4 more arriving at the end of the month. I just purchased the BMS ( battery management system which monitors all the cells. I have 5 batteries to go to finish the build. I took the car out for a 12.5 mile drive and used 33Ah of battery. This seems a bit high, but I managed to hit EVERY light on the way. At 50 mph I'm averaging about 60 amps draw on the pack ( which is 200 ah) So even with 5 batteries short I can still hit miles range. Once finished I should be at about 3235 hp and 700 ft/lbs of torque at 0-2800 RPM Enjoy... MO 3235 hp ??:eek::eek: |
Originally Posted by JackDidley
(Post 1581647034)
Regards, MO :D |
For those wondering how the build is going.
Still waiting for the last 5 batteries, Three are supposed to arrive this coming week. I'm hoping to be in the Route 66 Car Show in San Bernardino, CA this year. I'm currently at 173 volts with the 13 batteries ( 52 cells) Took a short trip around town today. went 14 miles and used 38 Ah's Given I have usable 160 AH (out of 200 Ah) should net me about 58.94 miles at 55 mph. 6,217 watts were used I will end up with about 240 volts with the 18 batteries for 38.4 Kw battery pack so If I take the 38.4Kw /6,217 = 6.17 So 14 miles * 6.17 = 86.47 miles estimated range. Mo |
(Post 1581723998)
Mo Very cool Mo. :cheers: |
Twice the range of Chevy's own Volt! :) I love it.
(Post 1581646362)
Given the torque and the range, you may have to replace rear tires before you recharge :rofl: This is one awesome C4! |
Originally Posted by ghlkal
(Post 1581730783)
That's 700 lb/ft available right away, correct? :eek:
Given the torque and the range, you may have to replace rear tires before you recharge :rofl: This is one awesome C4! Yes from 0- about 1600 RPMs falls to about 300 at 3200 rpms. I had to tone down the controller in REverse, I was chirping tires backing out of the garage... Not a good feeling LOL. Regards, MO |
:thumbs::cool:
Any chance that you would take it down a 1/4 track? Would be interesting to see how quick and fast it goes. Regards, Steve |
Originally Posted by STEVEN13
(Post 1581737301)
:thumbs::cool:
Any chance that you would take it down a 1/4 track? Would be interesting to see how quick and fast it goes. Regards, Steve At this point probably I'm guessing at least low 14's. 0-60's should be sub 5.7 sec. But perhaps my calculations will surprise me. MO |
For those who are interested in my range.
I took the car out for a drive Saturday, I'm constantly going farther in steps to see how the batteries and other things react. I went 22.5 miles ( which doesnt seem far to most people but going from lead acid I would have been very close to calling AAA LOL At 22.5 miles I used right at 50 Ah as I pulled into the garage. The batteries are 200 AH but you ner push them past 80% or in this case 160Ah. So my calculations are starting to prove out to be correct. So 3.2 times 22.5= 72 miles. This is with the pack as it is today ( rivaling the Nissan Leaf and the Volt. Once the remaining 5 batteries arrive the higher voltage will allow me to use less current so this will actually push the range very close to 100 miles . The nominal pack voltage right now is 166.4 volts so the 166.4 * 50 Ah= 8320 Wh consumed in 22.5 miles = 369.77 Wh/ mile this is "really" good as this number usually reflects about 10% of the weight of the car. So theoretically with me in the car it should weigh about 3697. Funny as the car before I converted it it weighed 3460 pounds. I removed 938 pounds from the car. The car was at 2522 pounds. I added about 1055 pounds back into the car. So the car should weigh in the neighborhood of 3577 pounds. Mo |
(Post 1581745188)
Mo |
so how fast is it compared to the 383 ? what is your new 0-60 ?
Originally Posted by Tom400CFI
(Post 1581746731)
I thought the Volt has a 40 mile range before the engine had to fire up?
Mo |
Originally Posted by 86GreenwoodVette
(Post 1581748417)
Right now I'm around 7 seconds running the controller at 700 Amps. Using first or second would haze the tires. MO |
I'm thinking that one of the auto manufacturers should give you a call and ask for you to help them with their electric programs. :thumbs:
