1966 flashing dash lights
I can't find my AIM and I want to replace the bulbs that flash when they heat up for the headlight and park brake warning.
Does anybody have easy access to the bulb number......... would my local NAPA be likely to stock? :cheers: |
bulb number 257. only the brake warning light should flash, the high beam is a standard bukb
(Post 1578007476)
i meant the warning light that the lights hadnt been rotated to open position....... apparantly it is supposed to flash as well. thanks bob |
Originally Posted by 66L72
(Post 1578007578)
many thanks
(Post 1578007948)
unless 66 is different then 67 only one light flashes and its the brake light. but I don't have a judging manual or a owners manual for a 66 to confirm:cheers:
(Post 1578007388)
Does anybody have easy access to the bulb number......... would my local NAPA be likely to stock? :cheers: Dennis |
Originally Posted by stingrayl76
(Post 1578008428)
63 thru 66 both the headlight and parking brake warning lights flash. Both use the 257 bulb.
Originally Posted by Dennis Beck
(Post 1578008477)
If you can't locate 2 in your area I have several xtras and could send you a couple.:thumbs:
Dennis My local NAPA has 6 in stock so I am good to go....... thanks anyway :cheers: |
Parking brake and headlight bucket use flashing bulbs and let me know if you can't find any. I got a box of a dozen of US Made bulbs from NAPA ten years ago just in case and can let you have one.
Pete |
Originally Posted by postalpete
(Post 1578008874)
Pete Cheers Bob |
If the ones you get from Napa are made "offshore" I would for sure bench test them before installing. I bought 4 of them and only 1 works.
Hey Guys
I'm restoring a 66 I just got and found the warning BRAKE LIGHT & LIGHTS bulbs were missing. I replaced the rest with what came out along with these two .. brake comes on when I pull the EM brake but... For the life of me I can't get the LIGHT warning to come on ... Is this light telling me the head lamps have not been raised to the upright position ? I tried this nothing lit up. Could it be I installed the wrong bulb..? What is the function of this light.. that the lamps are off or the |
Originally Posted by Rubc555
(Post 1594110825)
I tried this nothing lit up. What is the function of this light..
(Post 1594110825)
Hey Guys
I'm restoring a 66 I just got and found the warning BRAKE LIGHT & LIGHTS bulbs were missing. I replaced the rest with what came out along with these two .. brake comes on when I pull the EM brake but... For the life of me I can't get the LIGHT warning to come on ... Is this light telling me the head lamps have not been raised to the upright position ? I tried this nothing lit up. Could it be I installed the wrong bulb..? What is the function of this light.. that the lamps are off or the The 12v feeds to the switch on the gray/black wire and runs from one switch to the other, so check for the voltage there and then check the black ground wires. It's fairly common for those wires to pull off the spade connectors on the switches and they're not easy to get to. https://cimg7.ibsrv.net/gimg/www.cor...ebdfe5af87.jpg |
Here's a picture one of the telltale switches (sometimes called a limit switch, but it doesn't limit anything) on the car. The spade lug on each end should have the wires I described earlier.
https://cimg0.ibsrv.net/gimg/www.cor...071a713e89.jpg |
Hey I have to thank you so much for your time .. WOW
I installed the 257 bulb and ran the lights open close nothing yet but I got a directions my friend . Got this car 66 last month was a frame off restore finding issues with the lights and instrument panel lighting changed all the bulbs wow what a task I'm 6-6 so I'm hampered Good thing I got a little girl friend.. we got them all working now one extra socket above ignition and no opening can be seen I cant see what this might go .. this is excluding the two for the clock .. it has a gray wire silver socket any idea ? |
1 Attachment(s)
(Post 1594115079)
...now one extra socket above ignition and no opening can be seen I cant see what this might go .. this is excluding the two for the clock .. it has a gray wire silver socket any idea ?
Attachment 48064800 |
(Post 1578009467)
many thanks for the offer Pete but my Napa shows they have stock according to the computer........ will know for sure in a few days.
Cheers Bob Fortunately, I hadn't replaced the cluster yet and was able to find some at a local shop that specializes in older GM parts who sold me the correct ones. Gary |
Hey thanks a bunch guys. Felix you was right one wire was not hooked up.
Was not easy to see or get connected using a mirror and a flashlight but I Gotter . Both brake and light warning indicator do flash Wooooo Hoooo my friends I looked at the ignition and I do see your whole not typical of others but a hole. Last bug I hope till I reinstall the steering column . Thing is whoever did the frame restoration must've been in a hurry they installed a new radiator didn't bother to put the horns in on or plug anything in the problem with This was I'm trying to but it all pieces of the puzzle to get this thing back . I can't thank you guys enough you guys are amazing information on this site is awesome this is my first c 2 so it is a challenge for sure .. |
Hey Gary. Yeah I hear that my dash is still out so I'm checking and rechecking and then again before I but it back.. Next bug I got is the windshield pump not working got the rebuild kit today so wish me luck.. Thanks Again All
