vettaid dash kit?
Could those members who installed Vettaids gauge kit on their C-4s give an update on how the units are working out? The digital dash on my 89 finally gave out and I am trying to decide whether to repair it or replace it. Thanks in advance
fine piece....have one installed in my 85....much better (for me and my car's build style)......however I have a couple of issues:
speedo jumps around at low speeds; over 40 OK....they sent me a new speedo.....same thing......they are telling me it may have something to do with my speedo gear or speed sensor......it could be on my end....don't know for sure yet....... light doesn't work on my water temp. gauge (dash light)......don't know what happened there?? they sent me a new one though......have not installed it yet.....just can't see it in night driving right now.... the high beam indicator light in the middle of the dash is very, very, very, bright blue, blinding the driver.......they sent me a dimmer switch or something to install to bring down the brightness level......have not done that yet either..... the fit and finish is nice......I like the white face Auto Meters (that's the option I went to), so that alone is great and the tach is a HUGE improvement over stock....don't need a 10,000 RPM limit tach, but hey, it works great and looks great!! |
Originally Posted by 856SPEED
(Post 1578093558)
Originally Posted by Jims1988C4
(Post 1578093585)
Can you post a pic ???
pics!
pictures and information are available at www.vettaid.com if no one posts them here.
2 Attachment(s)
I love it. Had to change out 2 sensors. It was basically plug 'n play.
This is in my '89. The only thing I don't like is the blue high beam indicator. At night it's entirely too bright. And since you're eyes don't dialate to blue light (hence police cars having blue lights) it makes it very annoying. I ended up covering it with electrical tape. Picture 2 was taken before I switched out the oil pressure and temp sensors. It's a 6 speed too, so the trans temp isn't being used. |
Originally Posted by Black89Z51
(Post 1578098016)
What do you do for odometer readings when registering these things?
http://forums.corvetteforum.com/pict...ictureid=57060
[My steering column looks nothing like the one above! I would have taken it back...... I have posted these pics many times in the past......thought most have seen it.....it's also on my album pics if you want to see other mods..... |
http://forums.corvetteforum.com/pict...ictureid=57061
another angle...........took the "Vett Aid" logo off mine though......don't want that anymore than space around the steering column........hopefully someone took care of that above...... |
http://forums.corvetteforum.com/pict...ictureid=75914
Here's my car.......(now I need to change the interior to white seats/blue inserts and dark carpet......next project......the interior needs to be addressed.....original stuff in it........(other than the six speed shifter/dash cluster of course) :cheers: |
Has anyone used the Dakota digital replacement dash?
Originally Posted by oldalaskaman
(Post 1578098674)
is that the final fit around your steering column?
Originally Posted by Ray Quayle
(Post 1578100458)
(Post 1578104387)
I'm not sure there is a way to put the actual miles on the new odometer. I think you would have to call autometer to see if that would be possible.
I've had mine in for about 800 miles now and am very satisfied with it. My only issue is the bright light indicator... the blue LED provided in the kit is extremely bright. I put a drop of black paint on the top half of the indicator and that helps.
Its primarily a track car so I never installed the vent
http://i1136.photobucket.com/albums/...5/GEDC2315.jpg |
Vette dash gauges
[QUOTE=856SPEED;1578093558]fine piece....have one installed in my 85....much better (for me and my car's build style)......however I have a couple of issues:
speedo jumps around at low speeds; over 40 OK....they sent me a new speedo.....same thing......they are telling me it may have something to do with my speedo gear or speed sensor......it could be on my end....don't know for sure yet....... light doesn't work on my water temp. gauge (dash light)......don't know what happened there?? they sent me a new one though......have not installed it yet.....just can't see it in night driving right now.... the high beam indicator light in the middle of the dash is very, very, very, bright blue, blinding the driver.......they sent me a dimmer switch or something to install to bring down the brightness level......have not done that yet either..... the fit and finish is nice......I like the white face Auto Meters (that's the option I went to), so that alone is great and the tach is a HUGE improvement over stock....don't need a 10,000 RPM limit tach, but hey, it works great and looks great!![/QUOT |
You have responded to a thirteen year old thread. You might consider starting a new one.
