P1571 ASR Desired Torque
what is this code its coming up with no comm tcs???
DTC P1571 Traction Control Torque Request Circuit
Circuit Description The PCM supplies 5 volts on the desired torque circuit to the Electronic Brake and Traction Control Module (EBTCM). The EBTCM toggles this 5 volt signal to a ground in order to produce a duty cycle signal. The signal is proportional to the amount of engine output torque reduction requested by the EBTCM. The EBTCM supplies this signal when it detects a wheel slip. In order to reduce engine output torque, the PCM reduces the amount of spark advance and in some cases, the PCM disables a number of fuel injectors. This diagnostic tests for a Desired Torque signal failure. If the PCM does not receive the Desired torque signal, this DTC sets. Conditions for Running the DTC • The traction control has not failed. • The engine speed is greater than 500 RPM for 20 seconds. Conditions for Setting the DTC The desired torque signal is not received by the PCM for 3 seconds. Action Taken When the DTC Sets • The powertrain control module (PCM) stores the DTC information into memory when the diagnostic runs and fails. • The malfunction indicator lamp (MIL) will not illuminate. • The PCM records the operating conditions at the time the diagnostic fails. The PCM stores this information in the Failure Records. Conditions for Clearing the MIL/DTC • A last test failed, or the current DTC, clears when the diagnostic runs and does not fail. • A history DTC clears after 40 consecutive warm-up cycles, if failures are not reported by this or any other emission related diagnostic. • Use a scan tool in order to clear the MIL/DTC. Diagnostic Aids Important: • Remove any debris from the PCM\TAC module connector surfaces before servicing the PCM\TAC module. Inspect the PCM\TAC module connector gaskets when diagnosing/replacing the modules. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM\TAC modules. • For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616 . Using this kit prevents damage to the harness/component terminals. Refer to Using Connector Test Adapters in Wiring Systems. • Do not perform this diagnostic procedure if the customer's concern is not related to the ABS and/or the Traction Control system(s). • The following may cause an intermittent: - Poor connections; Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems. - Corrosion - Mis-routed harness - Rubbed through wire insulation - Broken wire inside the insulation • For an intermittent condition, refer to Symptoms . Bill |
Thanks for the reply I had my ebcm out to resolder what i could and put it back in and cleared all the codes after starting the car I got the pcm p1571 and the sdm u1040 codes I've been getting the 1255 code before thats why the soldering.. I have a used ebcm coming I've cleaned all the grounds and checked the fuses so i'm convinced ite the ebcm thats the problem wish me luck
(Post 1578918013)
Circuit Description The PCM supplies 5 volts on the desired torque circuit to the Electronic Brake and Traction Control Module (EBTCM). The EBTCM toggles this 5 volt signal to a ground in order to produce a duty cycle signal. The signal is proportional to the amount of engine output torque reduction requested by the EBTCM. The EBTCM supplies this signal when it detects a wheel slip. In order to reduce engine output torque, the PCM reduces the amount of spark advance and in some cases, the PCM disables a number of fuel injectors. This diagnostic tests for a Desired Torque signal failure. If the PCM does not receive the Desired torque signal, this DTC sets. Conditions for Running the DTC • The traction control has not failed. • The engine speed is greater than 500 RPM for 20 seconds. Conditions for Setting the DTC The desired torque signal is not received by the PCM for 3 seconds. Action Taken When the DTC Sets • The powertrain control module (PCM) stores the DTC information into memory when the diagnostic runs and fails. • The malfunction indicator lamp (MIL) will not illuminate. • The PCM records the operating conditions at the time the diagnostic fails. The PCM stores this information in the Failure Records. Conditions for Clearing the MIL/DTC • A last test failed, or the current DTC, clears when the diagnostic runs and does not fail. • A history DTC clears after 40 consecutive warm-up cycles, if failures are not reported by this or any other emission related diagnostic. • Use a scan tool in order to clear the MIL/DTC. Diagnostic Aids Important: • Remove any debris from the PCM\TAC module connector surfaces before servicing the PCM\TAC module. Inspect the PCM\TAC module connector gaskets when diagnosing/replacing the modules. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM\TAC modules. • For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616 . Using this kit prevents damage to the harness/component terminals. Refer to Using Connector Test Adapters in Wiring Systems. • Do not perform this diagnostic procedure if the customer's concern is not related to the ABS and/or the Traction Control system(s). • The following may cause an intermittent: - Poor connections; Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems. - Corrosion - Mis-routed harness - Rubbed through wire insulation - Broken wire inside the insulation • For an intermittent condition, refer to Symptoms . Bill Would a P1571 code, TCS, and ABS lights on the dash on. Effect the transmission shifting 2/3, as a result of bad wheels sensors. I know I need to replace the brakes, and most likely address the wheel sensors, but I also have an issue with the Trans not shifting into 3, (2000 4l60E automatic). After reading your post, I was wondering if the two issues are related. Or if I should focus on rebuilding or swapping the Trans, she has 180K on the clock. No codes present regarding the Trans on the DTC/DIC. |
Originally Posted by JamesPerconte
(Post 1606267765)
Bill,
Would a P1571 code, TCS, and ABS lights on the dash on. Effect the transmission shifting 2/3, as a result of bad wheels sensors. I know I need to replace the brakes, and most likely address the wheel sensors, but I also have an issue with the Trans not shifting into 3, (2000 4l60E automatic). After reading your post, I was wondering if the two issues are related. Or if I should focus on rebuilding or swapping the Trans, she has 180K on the clock. No codes present regarding the Trans on the DTC/DIC. My EBCM was fried after a battery shorted and melted the positive terminal post out clean out of it and my transmission still works the same as it did after replacing that battery. Now I just have the warm glow of extra warning lights on the dash to keep to make up for all the failed lights on the HVAC panel. |
