'61 Hardtop new weatherstrip between rear glass and deck...spliced???
1 Attachment(s)
Just got a new weather strip/rear glass seal from Corvette Central.
It looks like a early model weather strip was cut and the center section for the body line glued in. Are they all like this anymore??? It looks terrible. Where can a weather strip manufactured specifically for a '61/'62 be acquired, if anyone has bought one...??? Thanks...Stan |
Someone may correct me, but I think they came that way originally.
Originally Posted by Redbird
(Post 1579353656)
My top is in storage...and has a new rubber on it ...but was restored some years ago and never mounted. (distorted now). I think I would have noticed a splice...but maybe not! I'll have to get to out my storage room and see next a.m. Anyone else agree ...I'm shocked if that is the case? Stan.... |
Originally Posted by Stan's Customs
(Post 1579353680)
No Kidding????
Something else comes to mind...
If they can glue this weather strip together...then maybe it isn't really necessary to totally disassemble the hardtop (as advocated) to replace the rear weatherstrip. Just cut off the bottom part.. if that's all that is distorted/damaged...find out what kind of glue they use, and splice on a new bottom section...reinstall trim. End of issue....for a couple of hundred instead of $1500. Yes /No ?? |
Originally Posted by 62Jeff
(Post 1579353776)
Stan it's only been recently that a 61/62 main weatherstrip was available. Years ago all you could get was the 58-60 and you were to either splice in your original formed part, or just use the WS as is and let it form to the body split on the decklid. It's possible (even likely) that the WS on your restored top is a 58-60 WS without any splice.
Thanks for the input Jeff.. I'm sure that my top has a molded rubber made for the body split...may have a splice too, but I don't think so ( I'll find out sure on that tomorrow) It all looks like new...because it's been restored and never mounted. I bought it from Corvettes of Dallas after a customer bought a restored '61 ...but didn't want the top, even though he paid for it. I wound up with it 3 years later. That was 3/4 years ago...still hasn't been mounted ...but the rubber doesn't fit the deck (distorted). So... QUOTE=62Jeff;1579353776]Stan it's only been recently that a 61/62 main weatherstrip was available. Do you know of a supplier that sells them now? Stan... |
(Post 1579353776)
Stan it's only been recently that a 61/62 main weatherstrip was available. Years ago all you could get was the 58-60 and you were to either splice in your original formed part, or just use the WS as is and let it form to the body split on the deck lid. It's possible (even likely) that the WS on your restored top is a 58-60 WS without any splice.
(Post 1579353880)
Stan... |
(Post 1579354045)
Stan I'm sorry I may have misled you, but the WS you bought is what I was referring to.
No problem Jeff, I just misunderstood....no apology needed, my mistake.. I appreciate your input..always. Stan.. |
(Post 1579353880)
Stan... It's my understanding that Central has exclusive rights to it. Corvette Rubber told me that they can't sell it direct. Any vendor who is selling the rear bow weatherstrip, is getting them from Central. The rear bow weatherstrip has only been available for roughly 2 years, and at this point, I think the one from Central is the only one on the market. |
I did my top on 09 and used the parts from CC.It does have a splice but the color of the rubber seems to match better.
http://i35.photobucket.com/albums/d1...e/DSCF5667.jpg |
1 Attachment(s)
My rear weatherstrip.....I'm 98% sure this is original '61 rubber (the whole top in fact) as the top was stored in an attic for decades. No seams...the distorition is also why you shouldn't use those cheapie hoists with the strap at the rear...even with foam pipe insulation across this piece the hoist strap distorts the rubber permanently. You can buy the expensive $700 Glassworks hoist or use a modified cart from one of the vendors (which is what I will do henceforth).
If its just a few points in judging and that is the only repro rubber available Stan I think you're just going to have to use it. The problem with 'piecing' a bottom strip of rubber for the rear hardtop weatherstrip is that you still have to disassemble a bunch of the top and even then might have bad results. Glassworks quoted me $1,000 to replace the rubber a few months back including the part cost -- this is due to the major disassembly required. |
Originally Posted by Frankie the Fink
(Post 1579355696)
If its just a few points in judging and that is the only repro rubber available Stan I think you're just going to have to use it. The problem with 'piecing' a bottom strip of rubber for the rear hardtop weatherstrip is that you still have to disassemble a bunch of the top and even then might have bad results. Glassworks quoted me $1,000 to replace the rubber a few months back including the part cost -- this is due to the major disassembly required. Yep I may have to use it it looks like. Glassworks quoted me $1500 w/shipping though....for the same reason. (major disassembly) Mine doesn't need the upper portions replaced...it looks great. ( so does the bottom...just doesn't fit) If so then splicing the bottom strip on is no issue it seems to me. Just another splice....which would be nearly invisible. $1500 to avoid another splice on each end under the trim...something isn't right there! A splice of any kind is Jicky to me...but it is what it is. I'm sure not paying big bucks just to have 2 splices instead of 4. The bottom trim looks pretty straight forward to me...shouldn't be too difficult...with patience. |
The hardtop rear window removal procedure is explained on page 1-41 of the ST-12 manual (you have one of those right?) and you can decide for yourself if its something you want to tackle...
Just reading it made my eyes bleed... |
(Post 1579357708)
Just reading it made my eyes bleed... Only kidding...but after getting Mike to mount the front end...everything else seems like a piece of cake. |
If Mike ever retires from restoring C1s and C2s all other restorers automatically move up one notch.
(Post 1579358123)
He has an uncanny knack for the process...and works like a bat out of haydees. Man on a mission... He does more in 10 days than most shops get done in 10 months...No Exaggeration!! I've got a lot of pics of that trip to Mikes I plan on posting soon. I'm just about caught up with winterizing and catching up on things that piled up while I was gone.....finally! |
(Post 1579353656)
