HILBORN EFI on a LS3?
Anybody out there using a Hilborn EFI on a LS3? What would be the advantage of using this set up? Would it be drivable on the street?
Big question is why would you do that. The electronic is so much easier and will provide the same if not better performance.
Originally Posted by Gordonm
(Post 1579743433)
Cab are you talking about the GenIII LS3 or the LS3 Big Block from the early 1970's? |
Kinsler makes a intake for the LS engines, I just put there set up on an LSX 454 in a 33 ford. its a bad ass set up but wont fit under a hood thou, not without very short intake stacks
it is electronic and much better than a gm set up. |
Originally Posted by l88rocket
(Post 1579744010)
it is electronic and much better than a gm set up. Picture? Is it electronic or mech injection? |
Looks amazing, question is it it worth the $6,500-$7,500.
http://www.hilborninjection.com/prod...=429&CatId=174 |
I was talking about the moden LS3 - but I guess that answers my question. Why would you go back to old school gassers teck when the LS3 already comes with a nice tight little intake package?
They are good for low 900 hp small blocks because they flow about 2000 or so cfm depending on the bore size.
The Hilborne and kinsler 8 stack EFI are wonderful units |
there not old tech, they flow more cfm and produce more power than any gm style intake.
Originally Posted by MrForce
(Post 1579746021)
Sweet! I like the old school induction setups. Im running a modernized Tripower setup on my car.
They also make a crossram set up that lays the runners on there side, It will fit under a stock c3(or should)
I know it isn't an LS3, but here is a short stack electronic injection system.
http://images56.fotki.com/v127/photo...uise157-vi.jpg |
Originally Posted by Cab1
(Post 1579750490)
:cheers: Rick B. |
