Ported FAST 102's from Peak Speed Shop!
ORDER YOUR PORTED FAST 102 FROM PEAK SPEED SHOP AND SAVE!
http://peakspeedshop.com/Zen_Cart/im...ted-small3.jpg http://peakspeedshop.com/Zen_Cart/im...rted-small.jpg When you're putting on the best, why skimp? The professionally ported FAST 102 pumps out 8-12 additional RWHP over the non-ported FAST (depending on model and other mods). And, now you can get it from one source.... Peak Speed Shop. We're known for the quality of our porting work on Intake Manifolds and Throttle Bodies. Customers no longer need to buy from another source and then ship it to us for porting. Now, you can order your FAST parts directly through us! Model #146302 - LS1/LS2/LS6 - PORTED......... Just $1099.99 Model #146102 - LS3/L76/L92/L99 - PORTED... Just $1099.99 Model #146202 - LS7 - PORTED..................... Just $1149.99 FREE SHIPPING IN CONTINENTAL U.S. Place your order here: http://www.peakspeedshop.com/FAST.php Or, call us at 719-651-1952. |
ttt
ttt
ttt
ttt
ttt
Can you please elaborate on what is ported. Are the intakes taken apart and ported? How deep into the runners are you porting. Any more pictures of the work?
Originally Posted by z0sleeper
(Post 1580036454)
ttt
ttt
ttt
ttt
The "Model #146302 - LS1/LS2/LS6" - This uses stock LS1 style fuel rails?
Originally Posted by RideZX6R
(Post 1580135680)
Originally Posted by peakspeedshop
(Post 1580136695)
No, it actually uses the stock LS2 style fuel rails with a spacer that allows you to use your stock LS1/LS6 injectors. The FAST part #146021 is the kit that LS1/LS6 owners can get that includes the fuel rails and spacers. LS1/LS6 owners will also need the throttle body adapter plate that allows you to bolt your 78mm throttle body up to the 102mm opening. If you upgrade to the LS2 90mm or Nick Williams 102mm throttle body, you don't need this adapter but you will need the wiring harness adapter that allows you to plug these throttle bodies into your LS1/LS6 wiring harness. All of these parts can be purchased on our website at http://www.peakspeedshop.com/.
(Post 1580144127)
I have an LS2 T-body and adaptor harness, just wondering if I could use my own rails. So I'd need a rail kit or OEM LS2 rails, Thanks!
ttt
ttt
How much extra hp with a ported fast do they expect over a factory ported manifold on an LS7?
Originally Posted by BLDK SIX
(Post 1580192810)
Radical Ported LS7 intake manifold gets around a 14 rwhp gain over unported LS7 intake manifold. Basic Ported LS7 intake manifold gets around a 9 rwhp gain over unported LS7 intake manifold. |
