As other posters have mentioned, your actual type of driving will dictate your choice. I also believe your age will make a big difference on what you will find acceptable.
Much like other posters Ive had a wide range of axle ratios in different vehicles. Ive had 3.08, 3.36, 3.42, 3.73, 4.10, and 2.73 with od. When I was 20 I had a car with 3.42s, and it seemed ok on the highway. When I was 21 I had a car with 3.73s, and it seemed ok on the highway. When I was 25 I had a car with 4.10s, and it was tolerable on the hwy. When I was 35 the car with 4.10s was not pleasurable anymore. I will be 37 this year and my 3.36 vette seems to be a decent compromise all around, even though sometimes even this gearset seems a little restrictive on the highway. 10 years ago I would have said that my future [present] self is a wuss. I think its age, and exposure to the comfort of more modern cars that makes it harder to put numerically higher gears in a car. |
Think we're all just getting spoiled now, and with today's availible tranny's and gas prices, why not. My daily 08' Pontiac GXP 3.6L, 6 speed auto, will basically trounce most C3's, and about 1800 rpm @ 70 mph, getting 28 mpg. My C6 M6, is about 1500 rpm @ 70 mph, with similar fuel milage to my daily car. Today's tranny's are the real stars. Why not take advantage of them. As mentioned earlier, have another car originally with a TH-350. Now has a 700R4 with lock up od, and the cat's meow.
I went from a 3.08 to a 3.55, and it was a big difference off the line. However, I had already changed the 400 auto to a 700R4.
FYI: If I would have known about the 2004R transmissions I would have done that instead for the closer 1-2 gears, but the 700 does fine. |
Okay, so here's another option/question.
What if I leave the 3.08 rear and add a 700r4? I've got one in my C2 that I've been considering swapping out for a TKO. |
Originally Posted by bashcraft
(Post 1580223791)
2 years ago I switched from 3.55 to 3.08. I was tired of the engine screaming when on the highway. Much better now.
It will feel better in first gear only but you will be lugging the engine on the highway. 3.08 is too tall of a gear for an od. 3.55 or 3.73 is best for an od. It gives you the best of both worlds, acceleration and economy. Just going to a 3.36 would be a big help.
Mike |
Thanks to all.
I think my plan will be to look for a used 3.55 rear end and do a swap. Then I'm set for any trany swap out, whenever I decide to do it. If I don't, then I've still got the SOTP feel I was looking for. |
So, did you ever find your 3.55? I'm looking for the same swap and wondered what you ended up doing.... I have a forum member that is interested in a 3.73 swap for my 3.08that would be great off the line but beyond that a bit harsh, especially with headers / sidepipes.....
Looking to swP A 4.11 for a Chevy 3.55 gear differential set up
Originally Posted by qwank
(Post 1580212851)
I would just try and find a good used 3.55 rear diff and swap it in. they pop up in the for sale section every once and awhile.
Where do I find these 3.55 rear ends? I am willing to horse trade my original 4.11 factory 6 lug out of my 64 truck. I have already put new 5 lug disc on front. S this gives the added value of having 5 lug in the back. Now I can rotate my tires and get good highway performance. Tks for any help - Steve |
I want to swap pout my original 64 chevy truck differential 4.10 fro a 3.55.
Originally Posted by Billysvette
(Post 1580224133)
I have a 3:55 rear and its great,it is the best performance all around gear,any mechanic will tell you that.Yes it does rev a little going 70 mph,but its not that bad,i had 4:11,4:56 gears and they were bad on the belt way.:ack: You will be happy with 3:55 gears,guarantee it. Remember ,3:55 is the best" ALL AROUND" gear ratio for you. A 3:08 gear makes my car run like a turd.Its just good for high mph driving.And saving gas i suppose.
Tks - Steve |
Originally Posted by Old Chevy truck guy
(Post 1593441559)
Help Needed: - I want to swap out my original 64 6 lug chevy truck differential 4.10 for a 5 lug 3.55. Where do I find a complete axle to axle unit? What year model gms / chevys have this 3.55?
Tks - Steve |
Old Chevy Truck Driver:
Do you own a corvette? if so what year? How can you have a truck differential in a C3 corvette that comes from the factory with a independent rear suspension? There is no axle to axle on a C3 corvette. |
Sorry but no - I am new to this posting stuff - Sorry.
(Post 1593441586)
You have a truck rear end in your Corvette?
Originally Posted by MelWff
(Post 1593441588)
(Post 1593441767)
I guess this is where i am supposed to put a new Post?????????? First day- so sorry yall. Anyway I am trying to find a swap/trade/buy/sale something to switch out my original 1964 6 cyl 6 lug Chevy 12 bolt rear end, to a 5 lug 3:55 gear ratio. My understanding is that my original is a 4:10 or a 4:11 gear ratio. and I think PT also???? Runs great now, no road noise or whining. So what Makes and/or Models can I look for in the barns and weeds to get me going? I hear go back to a 10 bolt. Any horse trading out there? Too difficult for beginner to change out all the hog head, axles, brgs etc. Tks -Steve
Tks
(Post 1593441877)
This forum is for Corvettes. You'll have better luck here http://www.67-72chevytrucks.com/vboard/
That is a great forum, I am a member there as well.
Sorry, but if you don't know the diff between a Corvette gear and a truck gear you might be up for a little reading on both first.
Trucks were generally made for hauling and pulling, thus the stiff rear gear. Not for sure if a highway gear could be ordered, but it would probably be somewhat rare. |
3.36 200 r4 roller engine 350, serp drive....electric fans, DPFI, and happy as a clam.....
~2400 rpm at 80 cruise........and I get passed fairly regularly.... but it's lesser cars trying to prove a point...... :D:thumbs: |
Originally Posted by ratflinger
(Post 1593450415)
