1,870 HP so far.. New Texas Mile Build
Top Speed Corvette C5 Z06
Built and Tuned by Hinson Motorsports 4-27-2012 We have arrived at the Ohio Mile! http://hinsonsupercars.com/Images/C5Racecar37.JPG http://hinsonsupercars.com/Images/C5Racecar36.JPG http://hinsonsupercars.com/Images/C5Racecar35.JPG http://hinsonsupercars.com/Images/C5Racecar34.JPG 3-23-2012 Unfortunately, we had to postpone the trip to Texas. We simply ran out of time to test before the race, and that is a long haul to ride untested. So we're planning to attend the Ohio Mile, which has 4 events this year. We'll be tested and ready. http://hinsonsupercars.com/Images/C5Racecar33.jpg 3/23/2012 New numbers are in! 2,246 HP @ 7,800 RPM 34 psi http://hinsonsupercars.com/Images/EngineDyno1.jpg http://hinsonsupercars.com/Images/C5Racecar32.jpg 3-20-2012 We made our first pulls on the engine dyno! We made 1,870 horsepower on low timing and 27psi. We're turning up the boost and timing tomorrow. We'll run out of injector around 2,400 horsepower. Special thanks to Young's Performance, Lane Culver, Butler Performance, Ryan Carpenter, Buddy Anderson, and Noah Mitros for making this happen so quickly. 3-20-2012 We are headed for the Texas Mile on March 23-25! We are thrashing to complete the project now (3/20/12). We ran 224 mph on low boost with our previous build. We're looking to beat our own record and eventually compete for the world record for the fastest piston powered car. This new car is a combination of C5 and C6 parts resulting in extreme performance. We have built on the information gained from our previous car, and this ride is looking to push the boundaries for standing mile racing. http://hinsonsupercars.com/Images/C5Racecar30.jpg Build Specs Shortblock 427ci RHS Aluminum Tall Deck Block (Assembly & Machining by Butler Performance) Callies Ultra Center Counter Weight Billet Crankshaft Aluminum Connecting Rods Diamond Pistons Custom High Capacity Oil Pan from Doug Lee Engineuity Top End TEA Trickflow 245cc Cylinder Heads Crower Roller Rocker Arms Comp Pushrods Custom Comp Solid Roller Camshaft GM EFI Carb Style Intake Manifold Turbo System Custom Turbo Setup with 118mm Turbo 5" Downpipe Custom Air/Water Intercooler Tial Blow Off Valves Tial Wastegate Computer & Fuel Holley EFI Dominator System Bosch 160 lb Injectors FuelLab Fuel Pumps & Regulator Transmission & Rear Differential RPM TR6060 Transmission RPM ZR1 Differential with Quaiffe LSD SPEC Twin Disk Clutch Roll Cage & Body 25.5 Roll Cage Custom Adjustable Rear Wing Wheels & Tires True Forged Wheels 18x12 & 18x10 Hoosier R6 Tires 345/35/18 & 275/35/18 http://hinsonsupercars.com/images/C5Racecar1.JPG This is a custom tall deck 427ci solid roller engine built in partnership with Butler Performance. The guys at Butler Performance handle our big cubic engine builds. These RHS blocks are great when they're in capable hands of a great machine shop. Give us a call to help plan your next race engine build. http://hinsonsupercars.com/images/C5Racecar2.JPG Getting ready for the engine dyno. http://hinsonsupercars.com/images/C5Racecar22.jpg Amazing craftsmanship by the guys at Hinson Motorsports. http://hinsonsupercars.com/images/C5Racecar3.JPG Shameless plug for our friends at RHS & Total Engine Airflow/TrickFlow. We stock and use these great manufacturers for our personal and customer use. Let us know how we can help you assemble your next combination of parts! http://hinsonsupercars.com/images/C5Racecar20.jpg RHS intake spacers for the tall deck build. http://hinsonsupercars.com/images/C5Racecar24.jpg Forced air enters here. Intake is a GM piece with custom fuel rail solution by HINSON Motorsports. An intake elbow plate has been bolted down to the top. We will custom fabricate the elbow to work on this engine. http://hinsonsupercars.com/images/C5Racecar4.JPG A billet alternator bracket built by Lane here at the shop. Got amps? http://hinsonsupercars.com/images/C5Racecar19.jpg Custom water plates for -12 AN cooling connections. Built in house at Hinson Motorsports. http://hinsonsupercars.com/images/C5Racecar5.JPG Custom high capacity oil pan with trap doors for fluid control. http://hinsonsupercars.com/images/C5Racecar21.jpg Custom external oil pressure regulator on race oil pan. http://hinsonsupercars.com/images/C5Racecar6.JPG Amazing craftsmanship by Buddy & Lane at HINSON Motorsports. Great work guys! http://hinsonsupercars.com/images/C5Racecar27.jpg 118mm Turbo - It's bigger than you think. ;) http://hinsonsupercars.com/images/C5Racecar18.jpg Don't get sucked in :) http://hinsonsupercars.com/images/C5Racecar25.jpg 5" Downpipe. http://hinsonsupercars.com/images/C5Racecar7.JPG Lots of boost = Twin BOV. http://hinsonsupercars.com/images/C5Racecar8.JPG Funny car cage for driver protection. Still under progress when picture was taken. http://hinsonsupercars.com/images/C5Racecar9.JPG This is an all business interior featuring a 25.5 cage for protection. http://hinsonsupercars.com/images/C5Racecar10.JPG Intercooler and engine water tanks in the trunk. All fabricated in house. http://hinsonsupercars.com/images/C5Racecar16.jpg Running a TR6060 and ZR1 differential with Quaiffe LSD. Thanks to RPM Transmissions for their support on the initial build in 2011. http://hinsonsupercars.com/images/C5Racecar26.jpg SPEC Twin disk from last year's C6 race car. Thank you SPEC for the continued support in 2012. http://hinsonsupercars.com/images/C5Racecar17.jpg High rise hood to clear the intake elbow. http://hinsonsupercars.com/images/C5Racecar11.JPG Custom adjustable rear wing. http://hinsonsupercars.com/images/C5Racecar12.JPG Rear wing support for additional drag and down force. Braces supported by custom structure built behind the rear bumper. http://hinsonsupercars.com/images/C5Racecar29.jpg True Forged 18" wheels. http://hinsonsupercars.com/images/C5Racecar15.jpg Looking to put a "2" in front of that horsepower quote. http://hinsonsupercars.com/images/C5Racecar13.JPG Old sticker from previous life as a single turbo 76mm. Kinda funny in today's form.. |
Holy crap thats sick!!!:thumbs:
Just added the engine dyno video.
Looking good guys :thumbs:
Glad to see this.
some times people don't understand what needs to be done to break records ..congrats to all hands on your build :thumbs: i admire anyone with passion for a cause ..im sure your happy about this build as well good looking parts list
ttt
Dam guys you are going for it this time for sure. Just a work of art for sure....Good luck on the new record....Man that thing is for sure one hell of a turbo on a car...Robert :thumbs:
Looking more forward to the Mile now, i thought I couldn't get any more psyched!!!!
Wowzers!!!!!
Why not use a coupe for better aero?
Be carefull not to step in front of that sick turbo when it's spinning high rpm's. Freacking suck you in like a jet engine dammmmmmmmmm. Need one of those for my car and toss my f-1.:yesnod::yesnod:
Wow that is a sick setup and looking forward to seeing this baby at Beeville:rock:
WTF!!!That TURBO is Half the Size of that Engine...Awesome!!!!!!!!!!!!
Awesome! Good luck with your goals.
Damn that is a huge turbo! That is one awedome build. The armagedon package lol. Can't wait to see the numbers. More excited its in a c5 z platform :)
Nice to see people are still giving the C5 some love. :yesnod:
Can't wait to see what it does once it's turned up. True Forged wheels look nice! I think I'll get me a set! :rock: |
Good luck on your goal, awsome build :thumbs:
Originally Posted by 95wht6spd
(Post 1580333225)
Maybe just fab'in up a piece to attach the top roof to the rear deck (essentially creating a coupe type airstream)... |
Crazy HP numbers mang! Great looking car and the Fab work is out of this world. Looks so clean and well put together. Great job guys.
After all that work/money/time, why bother with an unmodified GM manifold? Seems like a custom piece (equal runner length with a plenum) would be a drop in the bucket compared to the price of the build so far, especially since you have already given up on the stock hood.
Not trying to hate, just wondering out loud. I love this build and I am looking forward to seeing the mile times! Jack |
