Change oil light on
Change oil light on. What does this mean? Just had my oil changed last week.
Thanks for your help |
It means you didn't reset the oil light when you had it changed. The instructions are in the owners manual, and posted in a sticky at the top of the C4 General section.
Sorry, I lied. The sticky is in the C4 Tech section. Anyway, here is what you do: 1. Turn the key to RUN, but don’t start the engine. 2. Press ENG MET on the Trip Monitor. Then, within five seconds, press it again. 3. Witbin five seconds, press and hold GAUGES on the Trip’Monitor. The CHANGE OIL light should flash. 4. Hold the GAUGES button until the CHANGE OIL light stops flashing and goes out. This should take about ten seconds. When the light goes out, the monitor is reset. If the monitor doesn’t reset, turn the ignition off, then try again. |
Just reset the light. Which the key in the run postion but not running hit the ENG/MET button twice within a couple seconds of each other. Then press and hold the gaugues button until it flashes and turns off.
Originally Posted by U DREM 2
(Post 1580674792)
Thanks for your help Pete made a video its in the stickies at the top of this forum. |
Thanks all on road trip
(Post 1580674792)
Thanks for your help So, follow Mark's instructions and you might need to replace "Gauges" with "Range" button. RANGE button (1990-1991) GAUGES button (1992-1996) on the Trip Monitor |
Originally Posted by RollaMo-LT4
(Post 1580674898)
You didn't list the year of your car.
Originally Posted by PLRX
(Post 1580674909)
Well his profile shows a C6, but he posted in here. :lol:
(Post 1580675011)
Oh, that's funny. :rofl:
