56 grill teeth.....
i've been fitting teh chrome, bumpers grill etc on teh 56, to see if i need to do any glass work to make it it right,,, i have a set of grill teeth that i got a while ago, and in cleaning them up, i noticed the numbers in them don't necessarily co-inside with the size of the teeth... i have them numbered and sized as follows,,,
6-5-4-2-2-2 then c-2-2-4-5-6... as you can see, it looks like i need another 2, but teh c taht i have is exactly the size of all the 2's.... so, do i need another 2, or should the c be larger than the 2's i looked in a parts catalog i have and they list 6-5-4-1-1-1-c, etc,,, but it could be a typo.... i was tripping over grill teeth yesterday at carlisle, not realizing i was one short!!!!!!!!!!! thanks in advance for any help i can get sorting this out,,, |
#C is for the center tooth only , the teeth are cut to fit the center bar contour as you move from center L and R!:thumbs:
Originally Posted by 1955 copper
(Post 1580676691)
in my case they are #2.. got any idea why why teh next size teeth i have are #2,, and teh catalogs call them #1? thanks again |
Noland Adams resto guide page 413 lists for 53-57 the following:
6 5 4 1 1 1 c 1 1 1 4 5 6 and the 58-60 are: 5 4 4 1 c 1 4 4 5 No idea what a 2 is.... |
Originally Posted by toms silver 60
(Post 1580677379)
6 5 4 1 1 1 c 1 1 1 4 5 6 and the 58-60 are: 5 4 4 1 c 1 4 4 5 No idea what a 2 is.... thanks for the reply... |
tooth stuff
3706425 is a 1 for early and late cars
424 is a c for early and late cars 427 is a 4 for early and late cars 428 is a 5 for both 429 is a 6 for early Get a copy of Noland's book, more than you will ever need. The teeth are a pita to line up and install, but they give you a lot of access to the radiator area, much better than the 61-62. It is amazing that GM made each one just a little different, just like the eyebrows.... But, they make the car look a lot better which is why you see them on 61-62 restorods. |
(Post 1580682166)
dunno
I bought a used set and ran into a mix of teeth, some had numbers that didn't match Nolan's book, but I figured out there were very small differences in the teeth and made them work. It's important to have some adjustments as the clearance to the surround is small. good luck:cheers:
(Post 1580682296)
like i said, i was tripping over teeth at carlisle on friday, and just realized i needed one!!!! can you confirm the C tooth is the same height as teh teeth next to it?? |
Anybody got a tooth set out there?
The center tooth appears to be the same height, but like you know, there is very little difference in the tooth dimensions. I believe the difference in notch depth from one side to the other is one of the main differences, as you flip a tooth to make it point correctly on the opposite side of center. (Confused yet?)
Maybe somebody out there with a loose set can do some measurements. :cheers: |
(Post 1580684315)
Maybe somebody out there with a loose set can do some measurements. :cheers: still stumped on teh 2's tho.... altho,, i still need a bar to mount them on,, which i posted in teh parts section,,, it may all come together yet... |
I typically see a few spare teeth if not entire setups at the Kissimmee winter regionals down here. There should be a bunch of vendors who could help you out up there in PA if you ask around. If you're a MASACC member you can put a free ad in their regional newsletters. :cheers:
(Post 1580684572)
regards.. |
People put some teeth upside down and don't look straight ,all original teeth have the part number up not down .:toetap:
(Post 1580684858)
thanks... |
back to 55 copper
(Post 1580684858)
(Post 1580688292)
Aren't the notches different depths so the teeth point straight ahead if they are installed on either side? That was my recollection..
update
Originally Posted by knockbill
(Post 1580688687)
you may be right,,, i haven't assembled mine yet...
