front end shake
Hello folks, (87 convertible, stock L98)
I noticed a problem last couple days, it seems when I hit the 50mph mark or in the vicinity of, give or take, feels like the steering wheel shakes, speed up it goes away, slow down it goes away also, I can speed up to 100 mph and it feels fine or below the 45-50mph mark I feel nothing. Any ideas what might be causing this, I thought wheel balance, but it would normally shake all the way up to high speeds then (usually) figured if it was any major front end part that it would shake all the time also. I am open for ideas as to what to look at that could be causing this. thanks. |
Sounds like wheel balance to me.
Originally Posted by steven mack
(Post 1580733546)
Hello 87 vert here also. just took my wheels in for balance while replacing the brakes and rotors the guy here said two were good and he tweeked two I have the same thing happening to me same speed range and everything you describe we checked bearings when we did brakes so Im clueless going to take it in for front end alignment to the same guy and let him drive it and see what he comes up with going to keep watching this post to see what you find
Don in KY |
Originally Posted by KYbaldguysC4
(Post 1580745418)
Don in KY |
