exhaust manifod help
Hi Everyone,
A quick question on the 81 original exhaust manifolds, Is there a aftermarket manifold that would bolt up to the factory exhaust pipes without modifying? |
These will do what you want. Not as much power gain as long tube headers. Available in 2" or 2 1/2" flange.
http://www.vetteheaders.com/servlet/...rvette+Headers |
Yes Sir; Your Question, has many answers. How much do you want to spend? What H. P. gain are you looking for? If you have the original Stainless Steel 1981 & 1982 only, G.M. Factory block huger ones now, long tube headers are what is the next change should be. If you have cast iron manifolds & are on a budget, Factory S. S. are the way to gain around 14 H. P. No changes to existing head pipes. Have a great one. Gene
63mako and doctorgrene,
Thank you for your help. I was working with the original 81 exhaust manifolds. I wanted to remove the emission pipes (which I did) and have the manifold's ceramic coated. Unfortunately, they have some cracks in them. So I tried to have them welded but they are to thin. I would like more power but I am not able to spend much now. I believe the previous owner removed the original carb.air pump and possibly the distributor. I would like to keep the temperature down under the hood, don't have a bunch of money to spend. I was hoping to find a manifold that would just bolt up to the original pipes and head. The one's that 63mako found are very nice but more then I have to spend. Is there anything else out there that would fit my 81 Vette? |
http://www.mcjackscorvettes.com/ i think these pipes are some of the best but they are verry expensive .they will bolt right up.if you want cheaper pipes summit has some long tube ones that are verry resonable.but then you have to get them connected to the rest of the exhaust system.i would stop and think what you want to do with this car .you can do it cheap now and then do it again later or you can do it right this time and be done .i would check e=bay and this forum in the for sale section for factory pipes .
here is a cheaper alternative, i used these dormans brand before with good luck.
http://www.oreillyauto.com/site/c/se...make=Chevrolet |
Originally Posted by speedreed8
(Post 1580753642)
yea, that looks like the wrong ones, this is the one i used, fits either side.
http://www.oreillyauto.com/site/c/de...2385&ppt=C0022 |
FWIW: the stock 81 and 82 stainless manifolds are some of the best to ever come from GM. They amount to factory short tube headers. I agree with Doctorgene: keep them.
:thumbs: |
(Post 1580755454)
Originally Posted by mrcarguy
(Post 1580753149)
Thank you for your help. I was working with the original 81 exhaust manifolds. I wanted to remove the emission pipes (which I did) and have the manifold's ceramic coated. Unfortunately, they have some cracks in them. So I tried to have them welded but they are to thin. I would like more power but I am not able to spend much now. I believe the previous owner removed the original carb.air pump and possibly the distributor. I would like to keep the temperature down under the hood, don't have a bunch of money to spend. I was hoping to find a manifold that would just bolt up to the original pipes and head. The one's that 63mako found are very nice but more then I have to spend. Is there anything else out there that would fit my 81 Vette? Keep the shiny side up!:rock: Scott |
Originally Posted by scottyp99
(Post 1580759413)
Too thin to weld? I think you probably just need to find a better welder.
