1989 Vette - Distributor Ignition Module
Distributor Ignition Module - does this need a conductive gel as part of the install? I purchased a module from a local parts store, but I didnt
get one in the kit. Thanks |
Originally Posted by glewis954
(Post 1581432399)
Thanks .. I thought I was missing this when I purchased the mod
You want to use a heat sink thermal paste/grease. Usually
White in color. This allows the ignition control module to transfer the heat to the distributor base. Available at Radio Shack or most electronic stores. http://www.radioshack.com/search/ind...+compound&sr=1 |
Originally Posted by Hooked on Vettes
(Post 1581433300)
Originally Posted by higgyburners
(Post 1581433400)
I agree dont use the dielectric grease for this job, Use the Thermal paste.
(Post 1581433300)
Its more than likely thats what your car came with, I just changed mine out and the new one came with thermal heat sink paste. Dont take my word for it do a search here on the forum....if you feel the need to be vindicated. :flag:
Quick question fellas. I have heard this module can be behind hard to start and no starts on hot days or when the car is hot. Is this true?
Yes, that is correct.
There are other items that will cause a hard to start/hot day/hot engine no start. |
A bad ICM can also cause the engine to shut off and stop running at any time "Like on the highway going 70 mph"..Ask me how I know....:ack:...WW
Originally Posted by WW7
(Post 1581445847)
On my 87 it's between the right fender and heater box.
Originally Posted by Keystring
(Post 1581447867)
could this be the ECM?? can you send me a pic of your ECM location .. glewis954@aol.com |
Just to clarify.. the ECM (Electronic Control Module) is not the same as the ICM (Ignition Control Module)..
The ICM is under the distributor cap. The ECM (or computer) is under the right side of the dash. If you are talking about the ESCM (Electronic Spark Control Module).. It's on the right side of the blower motor housing,left side looking from the front....(at least in my 87) http://members.shaw.ca/agent86/Rear%...ompartment.gif |
(Post 1581448470)
The ICM is under the distributor cap. The ECM (or computer) is under the right side of the dash. If you are talking about the ESCM (Electronic Spark Control Module).. It's on the right side of the blower motor housing,left side looking from the front....(at least in my 87) http://members.shaw.ca/agent86/Rear%...ompartment.gif Thank you.. I have located all of the items.. ICM has been changed.. ESCM - ordering.. I am going to check for the ECM now.. Does the ECM have to be programed if I purchase a new one??? |
(Post 1581448548)
Keystring
(Post 1581448662)
Quite honestly, I don't know.. I've never had to change one.
No programming is necessary.
You will need to remove your PROM (chip) from your old ECM and install in the new one. Very easy to do. |
Originally Posted by TorchRedlt4man
(Post 1581448784)
You will need to remove your PROM (chip) from your old ECM and install in the new one. Very easy to do. Thank you for the information.. |
The ICM (Ignition Control Module) is inside the distributor.
You need to move the MEMCAL from the old ECM to the new one. It holds the program that runs your car. It's under a cover on the ECM housing held on by two 1/4" hex-head screws. It looks like this: http://www.misterpeachy.com/VettePics/MEMCAL.JPG |
