Upper radiator hose drip... HELP!
Ok...
My upper hose where it connects to the radiator... it drips from under the hose right where it connects to the upper radiator... I'm talking maybe the size of a quarter a night. I went out a bought a new hose, cleaned all the connections, installed the hose... same thing, the drip... I removed the hose and took fine steel wool and really cleaned it nice, so nice the brass now shines... same thing, that drip!!!!.. Is there anything i can use between the hose and radiator neck to stop this? Has to be something... help me out here.. Thank You!! |
Could be the brass pipe/nipple, that the hose is tightened onto, to radiator solder connection. They can be fragile and easy to make leak. mike...
Hi r70s,
I'm thinking the same thing as Mike. Just maybe a pin hole in the solder connection from the neck to the radiator. Could you tape a small piece of paper towel to the neck to see if where it gets wet would give you a clue to where the leak is? Good Luck! Regards, Alan |
I did think of that option.... so i did pull the hose back and watched it with an inspection mirror. I kinda feel the brass isnt truely round and there maybe some hills and valleys, the rad is over 42 years old.
OK. The hose is the "gasket". If it can not seal to the rad. pipe then it will of course leak. Good luck with it. mike...
Originally Posted by mds3013
(Post 1581661797)
You guys were right, i wasnt sure so i backed off the hose to the max and saw it... now.... a new rad isnt in the cards now, or having someone remove and repair it... Anyway to seal off the inlet/radiator connection? jb weld? |
If you are very careful, you could try to resolder it after draining the anti-freeze to a lower level.
Kairfull ! ! ! !
Originally Posted by loup68
(Post 1581663727)
take the car to a radiator shop and pull the top hose off and have them soldier it! Check with them first to see if the will do it that way.
Originally Posted by lvmyvt76
(Post 1581675125)
