Charge system fault
I have gotten this message twice now. I've been observing the voltage reading and I don't see anything abnormal but not sure where to go with it. I haven't done anything to the car since I bought it in June but it does have aftermarket audio with 2 amps. I believe the alternator was replaced by the previous owner not that long ago and the battery is about 2 years old. Any advice?
I have had it show up twice for maybe 2 seconds on start up but went right away. And I also just bought my Z well, Memorial day weekend but basically in June. But that was right after I bought it and never again since. Mine only had 22K on it when I got it and was a garage queen so I was thinking the battery might have just had a low charge as I have not seen it since June.
Yeah I don't get it. It shows up then disappears and no check engine light or anything. Will this throw a code I can pull?
As far as I can tell, the only DTC that could set under this condition is P1637, which is for the Generator L Terminal Circuit. However, I have not personally experienced this code being set. I've had the "CHARGE SYSTEM FAULT" once or twice in the last 5 years. The first time it occurred, I performed the applicable checks from the service manual, and everything checked out ok.
My advice: either perform the load check(s) called out in the manual or have your alternator tested at AutoZone (or somewhere like that). If everything is ok, I wouldn't worry too much about it until a DTC is set in conjunction with that message. |
Much appreciated I will get the alternator tested. I don't want to be stuck somewhere.
Charge System Fault '02 C5
I've been getting this message recently myself. After searching through the forum I went ahead and checked my ignition contacts. Great post Bill, thanks. My contacts were scorched just as badly as your pictures. Problem is, it didn't fix the problem.
I am still experiencing fluctuating voltage levels after driving 15-20 miles. I've had the alternator checked and they assure me it's putting out the required numbers as well as the diode being okay. Not only do I get the code but I'm also experiencing stutter and occasionally the engine will die. No problem to restart but very disconcerting. Is there something else to check or should I just go ahead and consider the alternator bad and change it out? BTW the battery is only a couple weeks old. Sorry, I've got a 2002 base model C5 with no mods at all. |
Zillionaire2 said:
Originally Posted by zillionaire2
(Post 1582282266)
Is there something else to check or should I just go ahead and consider the alternator bad and change it out? BTW the battery is only a couple weeks old. |
:willy: Seeing Charge System Fault message at initial start up really isnt a big deal and as long as it goes away within a few seconds after start up.
I would much worry about it. What concerns me is; What and how are you checking battery voltage????? If your are using the Dash Volt meter or the DIC digital volt meter,,, YOU ARE NOT seeing true battery voltage! Both of those meters shows the voltage that is being supplied to anything that the IGNITION SWITCH turns ON when you turn the key to RUN, ACC or Start Measure the battery voltage DIRECTLY from the battery terminals. If you want to make sure that your alternator is properly charging the battery, measure the large BATT terminal on the back of the alternator to chassis ground. It should be exactly the same as the POSITIVE battery terminal to chassis ground. IF,,,,,,,,,,,,, there is a difference between the two, you could have a poor connection at the starter solenoid where the wires connect: http://img.photobucket.com/albums/v4...7/DSCF0089.jpg http://img.photobucket.com/albums/v4...7/CIMG0889.jpg http://img.photobucket.com/albums/v4...ercharging.gif http://img.photobucket.com/albums/v4...lectricals.gif This LUG on the frame next to the battery is your CHASSIS Ground lug... It is very important that it is properly grounded and the connection is clean and tight!! http://img.photobucket.com/albums/v4...7/DSCF0008.jpg |
Here is why the IGNITION SWITCH voltage output can be different than measuring battery voltage directly on the battery:
IGNITION SWITCH CONTACTS burnt! http://img.photobucket.com/albums/v4...7/DSCF0021.jpg http://img.photobucket.com/albums/v4...7/DSCF0031.jpg You can repair/rebuild that switch: - C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html |
Originally Posted by Bill Curlee
(Post 1582284141)
I would much worry about it. What concerns me is; What and how are you checking battery voltage????? If your are using the Dash Volt meter or the DIC digital volt meter,,, YOU ARE NOT seeing true battery voltage! Both of those meters shows the voltage that is being supplied to anything that the IGNITION SWITCH turns ON when you turn the key to RUN, ACC or Start Measure the battery voltage DIRECTLY from the battery terminals. If you want to make sure that your alternator is properly charging the battery, measure the large BATT terminal on the back of the alternator to chassis ground. It should be exactly the same as the POSITIVE battery terminal to chassis ground. IF,,,,,,,,,,,,, there is a difference between the two, you could have a poor connection at the starter solenoid where the wires connect: 1. Just to make sure, the BATT terminal you speak of is the BATT connection in this pic, right? http://bob_skelly.home.comcast.net/~...2/image001.jpg 2. To test this, would I need to pierce the protective cover of the plugin to this terminal? |
Auhhhhhh,,,,,,, You know thats NOT a C5 Alternator,,, CORRECT??????????????????
NO,, The black rubber boot pops off the back and the terminal is easily accessed and measured http://img.photobucket.com/albums/v4...7/DSCF0068.jpg |
(Post 1582407458)
NO,, The black rubber boot pops off the back and the terminal is easily accessed and measured Thanks very much for the explanation sir! |
Bill, thanks again for the tip. I just went out and took some measurements with my multimeter and this is what I found:
Battery with car off: 12.1 Battery with car running and blower on high: 14.52 Alternator with car running and blower on high: 14.66 I started getting the Charging System Fault/Service Engine Soon light right after a long tube install. I replaced the battery and the situation remains unchanged. The engine grounds will be getting inspected/cleaned if necessary soon but in your opinion, how likely is it to be a bad connection at the starter solenoid given the difference in readings between battery and alternator and the recent activity around the starter with the LT install? just trying to temper my expectations on how involved this resolution will be. Thanks in advance for your help! |
Voltages look excellent BUT,, the solenoid would be the first place that I would check
Bill |
(Post 1582415150)
Bill |
