White face gauges
Anyone install white face gauges. Would like to see some pics.
Do a search for aftermarket gauges or autometer gauges and you will find all sorts.
I'm putting in Phantom's right now so I don't have any "after" pics but here is a pic with all but one gauge in the center cluster. http://i1228.photobucket.com/albums/...ugeCluster.jpg |
I kept original gauges but put the white face overlays on them. I like them, especially for 20 bucks...
https://lh6.googleusercontent.com/-U...204_140640.jpg |
I also installed the white face overlays on my original guages. It's easy and looks great.
http://i1168.photobucket.com/albums/...6/DSCF3592.jpg |
I've been checking these out. Lot cheaper the Autometer, and what could be more appropriate for a C3 than "Shark Gauges"?
http://www.hotrodhotline.com/pr/2011...ark_gauges.jpg |
No PIX, also no stereo/tunes.....and so I bent up a aluminum plate for the center gauges, that are white faced and the overlays done for the speedo/tach, my tach is from a 75-77 and so the white overlays don't line up on the bolt holes in the dial center, a little paint made it somewhat passable, the old '72 speedo was a stamped relief to the numbers too, so not really good either.....but unless stared at, it passes ok, the sides of the center plate are odd shaped plates screwed into the dash pads on either side, the top vent/wiper is stock piece, and it all fits in nice.....
:thumbs: |
Originally Posted by The Punisher
(Post 1582226939)
http://i119.photobucket.com/albums/o...Tachometer.jpg |
I like the white overlays. Is there a " how to " on installing them?
(Post 1582234664)
I'm not the best at writing a "how to" but I'll say this...I needed to do something with my gauges. They had surface rust and looked horrible. I very heavily contemplated the "Shark" gauges posted above....But I decided on the white overlays since they were cheap and my oem gauges did function......
The kit I purchased actually had several different year 'vette overlays in the package...I can't remember what all years it covered but there were several... I lightly scuffed my gauge faces with scotchbright pads and cleaned with alcohol cleaner...I used a small squirt bottle with a drop of soap to keep the vinyl sticker from "sticking" until I felt it was positioned correctly. https://lh6.googleusercontent.com/-E...122_114603.jpg I also decided since gauges were apart to go ahead and clean/paint housings.. https://lh3.googleusercontent.com/-L...122_105015.jpg https://lh6.googleusercontent.com/-2...122_104453.jpg https://lh4.googleusercontent.com/-v...122_104527.jpg As you can see they were kinda crusty....Installing the overlays was quite easy...You do not have to remove any needles...Just clean, spray light soapy solution and install. The little screws that hold the gauge faces on actually are used to align the overlays.... https://lh5.googleusercontent.com/-a...122_105026.jpg https://lh3.googleusercontent.com/-1...125_192346.jpg https://lh4.googleusercontent.com/-2...125_193124.jpg The little gauges were just as crappy.... https://lh3.googleusercontent.com/-B...122_123452.jpg After install https://lh4.googleusercontent.com/-R...125_195938.jpg https://lh6.googleusercontent.com/-q...125_195925.jpg All of it on my "work" bench... https://lh4.googleusercontent.com/-N...123_150255.jpg For $20 I was very impressed with the quality of the overlays, them including all the different year models in kit...saved me some bucks and looks great in my new black interior I think.... https://lh4.googleusercontent.com/-O...126_163153.jpg https://lh6.googleusercontent.com/-I...128_112321.jpg https://lh3.googleusercontent.com/-6...-41-39_682.jpg |
Nice. Do you have to remove the needles for installation ?
I removed mine. I suppose you could leave them in place but it would be a lot harder. Just be sure to put them back where you found them!
Auto meter C2 white face gauges. They're blue at night
Jim http://i156.photobucket.com/albums/t...2/P2221226.jpg |
Do not have to remove the needles. The overlay is pretty tough and I believe the instructions say you don't have too either....
where do you get the overlays??
Www.whitefacegauges.net
Originally Posted by rickslt4
(Post 1582257698)
Originally Posted by stopherjones
(Post 1582256444)
Once again....I did not remove my needles, nor did I "tear" the vinyl. It will go over quite easy without removing them.
I guess we had different experiences! Have you ever considered a career as a magician? I tried everything I could think of but still ended up pulling the needles.
