Hyperflash Harnesses on sale at Radioflyer Innovations
Put a stop to that pesky hyperflash from LED bulbs with Radioflyer's Hyperflash Harness. Safer than load resistors and easier to install.
Normally $65, now til the end of January, just $50! Order yours here: http://www.shop.radioflyerinnovation...arness-027.htm |
Just ordered mine:thumbs:
thanks for the order.
ttt
bump of the morning
Originally Posted by theradioflyer
(Post 1582911557)
Where can I find install instructions? |
Originally Posted by Yellow03Z06
(Post 1582936165)
Just got it today! Fast shipping:thumbs:
Thanks!
Will this work if you only install LEDs in the front signals?
Originally Posted by duramaxsky
(Post 1582938087)
ttt
Just ordered mine
Originally Posted by 8VETTE7
(Post 1582968227)
Is this hyperflash harness required for your LED Reverse lights?
Will this harness fix the hyperflash problem with LED lights installed just in the rear of the car?
I installed a set of Halo LEDs rear lights from JWmotoring and now having the turn signal hyperflash problem. |
Originally Posted by Z06ufgrad2002
(Post 1582980362)
Will this fix the regular turn signal intermitent flash issue like the others do?
I currently have no brake lights and the hazard switch is the main suspect. |
Originally Posted by J S Machine
(Post 1583013306)
(Post 1583013557)
If you're willing to try, I would give you a $20 discount off the harness to experiment. If it works, I can then market the harness as a fix for your issue as well. |
I installed my LEDs in the front today. Sure enough it had hyperflash. I then installed the harness and all is well. This is a great and easy to install kit. Is the box a relay or a 3 prong flasher? My curiosity has the best of me. My housings are not yet melted on top so the LEDs should prevent that. The previous owner pulled the DRL relay but I want them to work. A black car can be hard to see. :thumbs:
