Do you carry a jack in your corvette?
I would like to carry a jack in my C5 just in case of a flat tire. That said, any good sources for a low profile jack that will fit in our cars?
Thanks. Glenn |
Nope I don't carry one. Some guys used to talk about a Mercedes jack that would work.
I carry a standard scissor jack that you can get from Autozone and a set of RV leveling blocks the you can get from Walmart. Ride on the blocks to get the car high enough to get the jack underneath.
Originally Posted by meflyfrc
(Post 1582916528)
I don't want to have a lot of crap in the car, I'd sooner just call a tow truck. |
I have a small scissor jack that came out of a Nissan just in case, I also have a plug kit a few tools and a compressor.
Nope I don't carry one - I have Triple AAA
Plus there is no room for a spare either, you could get the C5 Z06 flat repair kit! Thanks,Matt |
A low profile jack fits under hockey pucks no problem. I bought one from Sears, been using it a lot in the garage for projects.
I have run flats. Don't not see the use for a jack if you don't have a spare, unless you have a compressor and plug kit maybe? |
I carry AAA - Premier
Hope they can help ... |
I carry an air compressor and plug kit, but no jack. I have emergency road service on my insurance policy and always carry a cell phone.
But, I do need to look for a small scissors jack that might work with the car. |
I do in the '66 not in the '03. :thumbs:
nope. It's called a $50/yr roadside assistance insurance rider with up to 100 miles of flatbead. Well, may be 50, I'd have to pull the policy ;-)
Portable air compressor and a bottle of fix a flat in my cargo area... doesn't take up hardly any room at all.
No run flats, jack or spare here;
nope. It's called a $50/yr roadside assistance insurance rider with up to 100 miles of flatbead. Well, may be 50, I'd have to pull the policy ;-) Portable air compressor and a bottle of fix a flat in my cargo area... doesn't take up hardly any room at all. |
I do carry a plug kit and a can of slime. been looking for a air compressor. Which ones are You using ?
Air compressor and Fix a Flat.
to each their own, but if you ever see the inside of a rim/tire that's had that put into it, you'll never do it again. 50/yr is awfully cheap insurance against having to replace a rim.
Originally Posted by Mr.Bill
(Post 1582916616)
Really no need for a compressor. If a plug and can of slime can't fix it, the wheel's coming off.
Dan |
Originally Posted by dmarkshark
(Post 1582917395)
And AAA premium. |
