ABS Unit Leaking !!
PN on my unit: GM ASM PN 25886839 EBU(?) 25866840
My ABS is leaking from the fitting/port in RED. Is this repairable? Is there any reason this cannot be sealed with JB Weld? Is there a function to this fitting/port? Is there any solution other than replacement? Is there a source other than new from GM? http://i20.photobucket.com/albums/b2...ps17cfdbd9.jpg :cheers: DH |
Originally Posted by Dirty Howie
(Post 1583019787)
Is this repairable? Is there any reason this cannot be sealed with JB Weld? Is there a function to this fitting/port? Is there any solution other than replacement? Is there a source other than new from GM? http://i20.photobucket.com/albums/b2...ps17cfdbd9.jpg :cheers: DH http://www.tonkinonlineparts.com/sho...ssembly=852894 http://img.photobucket.com/albums/v3...psd3cbf17a.jpg http://www.gmhightechperformance.com.../photo_10.html http://img.photobucket.com/albums/v3...ps2e133c0a.jpg I'm not sure, but I think you might have to buy the whole kit, which is GM part #89060341, Part #89060303. That includes part #4 along with part #2. At any rate, you'll need to do some shopping around Howie. That part 89060341, the control module, runs $628.55 at GM Parts Direct. If you shop around, you can get it for less. The auction site, you can get it for about half that. Part #89060303 the control modulator, runs $479.63 at GM Parts Direct. Anyway, here is another diagram http://store.gmpartshouse.com/parts/...agramCallOut=1 Hopefully you can get by with just part #89060303 |
Originally Posted by '06 Quicksilver Z06
(Post 1583019875)
So, what it is you're needing? The modulator valve? Part #2? #89060303
http://www.tonkinonlineparts.com/sho...ssembly=852894 http://img.photobucket.com/albums/v3...psd3cbf17a.jpg http://www.gmhightechperformance.com.../photo_10.html http://img.photobucket.com/albums/v3...ps2e133c0a.jpg I'm not sure, but I think you might have to buy the whole kit, which is GM part #89060341, Part #89060303. That includes part #4 along with part #2. At any rate, you'll need to do some shopping around Howie. That part 89060341, the control module, runs $628.55 at GM Parts Direct. If you shop around, you can get it for less. The auction site, you can get it for about half that. Part #89060303 the control modulator, runs $479.63 at GM Parts Direct. Anyway, here is another diagram http://store.gmpartshouse.com/parts/...agramCallOut=1 Hopefully you can get by with just part #89060303 Im not clear which is which. Is the control modulator #2 or #4 ? :cheers: DH |
(Post 1583019875)
http://www.tonkinonlineparts.com/sho...ssembly=852894 http://img.photobucket.com/albums/v3...psd3cbf17a.jpg http://www.gmhightechperformance.com.../photo_10.html http://img.photobucket.com/albums/v3...ps2e133c0a.jpg I'm not sure, but I think you might have to buy the whole kit, which is GM part #89060341, Part #89060303. That includes part #4 along with part #2. At any rate, you'll need to do some shopping around Howie. That part 89060341, the control module, runs $628.55 at GM Parts Direct. If you shop around, you can get it for less. The auction site, you can get it for about half that. Part #89060303 the control modulator, runs $479.63 at GM Parts Direct. Anyway, here is another diagram http://store.gmpartshouse.com/parts/...agramCallOut=1 Hopefully you can get by with just part #89060303 Thanks for those price checks. :thumbs: :cheers: DH |
(Post 1583019964)
Thanks for the help Ricky. My leak is from that recessed round port/fitting below where #5 is on main block part #2.
Im not clear which is which. Is the control modulator #2 or #4 ? :cheers: DH In this one linked to below, it looks to be #2 as well. The module in this diagram below is #1. or #4 in the above diagram The module, or that back piece, is the more expensive of the two. http://store.gmpartshouse.com/parts/...agramCallOut=1 I recall reading somewhere in the C5 section, a few of these going bad, and the owners getting good will repairs out of warranty. If that doesn't work, then I have seen a few of these on the internet for sale. But I'm almost certain that whenever you fool with that block, you need a Tech 2 when you go to bleed your brakes again. That's why when people bleed their brakes, or change brake fluid, they never bother with that block and some of the old brake fluid remains in it. Anyway, you might try the guys referenced in this thread too. http://forums.corvetteforum.com/c5-g...ol-module.html |
The C5s did have a problem with the abs module. When I had an 02Z, I sent mine to a company back east (can't remember the name but can be found with a search). A lot of guys were sending them out for a rebuild for a couple hundred bucks. It took care of the problem and was much less than buying a new one.
Originally Posted by 383vett
(Post 1583023184)
But I can't have my car down while its removed, shipped, repaired and returned :willy: :cheers: DH |
(Post 1583023477)
I think you are referring to absfixer.com which Ricky in the above link, and someone in my other thread pointed out.
But I can't have my car down while its removed, shipped, repaired and returned :willy: :cheers: DH You may be able to buy a core in here, or at a salvage yard, or they may have some ready to ship out. Give them a call. |
(Post 1583023548)
Simple matter.
You may be able to buy a core in here, or at a salvage yard, or they may have some ready to ship out. Give them a call. Will be checking later and tomorrow on prices. Likely will be close to same price buying use one in good condition as buying core and repairing. But am open to any ideas as long as its quick :thumbs: :cheers: DH |
(Post 1583019875)
http://www.tonkinonlineparts.com/sho...ssembly=852894 http://img.photobucket.com/albums/v3...psd3cbf17a.jpg http://www.gmhightechperformance.com.../photo_10.html http://img.photobucket.com/albums/v3...ps2e133c0a.jpg I'm not sure, but I think you might have to buy the whole kit, which is GM part #89060341, Part #89060303. That includes part #4 along with part #2. At any rate, you'll need to do some shopping around Howie. That part 89060341, the control module, runs $628.55 at GM Parts Direct. If you shop around, you can get it for less. The auction site, you can get it for about half that. Part #89060303 the control modulator, runs $479.63 at GM Parts Direct. Anyway, here is another diagram http://store.gmpartshouse.com/parts/...agramCallOut=1 Hopefully you can get by with just part #89060303 PN on my unit: GM ASM PN 25886839 EBU(?) 25866840 :cheers: DH |
(Post 1583023477)
But I can't have my car down while its removed, shipped, repaired and returned :willy: :cheers: DH :cheers: |
(Post 1583024081)
WHY IS THE PN ON MY UNIT DIFFERENT ????????
PN on my unit: GM ASM PN 25886839 EBU(?) 25866840 :cheers: DH How much is it? |
(Post 1583024081)
(Post 1583024335)
I don't know.
How much is it? :cheers: DH |
(Post 1583024542)
Because you need to fine the pn of a leaky unit. :thumbs:
I thought I would see the same PN that Ricky found but its not. :cheers: DH |
(Post 1583026175)
Seriously, I need to figure out if there is more than one part number for this unit. If I buy a used one I need to know its right. And need to make this happen quickly.
I thought I would see the same PN that Ricky found but its not. :cheers: DH From what I have seen, these units have multiple part numbers. The number on the unit, which you have seen as multiple part numbers are the manufacturer part number, and they change with the calibration level installed. Just be sure to get one with the correct GM part number, which will probably not be identified on the unit. It will probably have to be programmed to your VIN anyways. |
Originally Posted by erick_e
(Post 1583026221)
Howie,
From what I have seen, these units have multiple part numbers. The number on the unit, which you have seen as multiple part numbers are the manufacturer part number, and they change with the calibration level installed. Just be sure to get one with the correct GM part number, which will probably not be identified on the unit. It will probably have to be programmed to your VIN anyways. How am I supposed to know if I am getting the correct GM part number if it doesn't show on the unit ??????? So I am curious to see what other have for manufacturers PN. Can you check yours? And I assume you mean the TechII will program the unit. Man, this is confusing. Thanks for your help :thumbs: :cheers: DH |
(Post 1583026505)
Erick
How am I supposed to know if I am getting the correct GM part number if it doesn't show on the unit ??????? So I am curious to see what other have for manufacturers PN. Can you check yours? And I assume you mean the TechII will program the unit. Man, this is confusing. Thanks for your help :thumbs: :cheers: DH My car is in the shop having the valve guides checked, so I can't take pictures of that module. However, I took pictures of the 2010 module I bought that I was going to use to add traction control. http://imageshack.us/a/img541/1459/dsc5278r.jpg http://imageshack.us/a/img23/1359/dsc5277a.jpg http://imageshack.us/a/img823/219/dsc5276c.jpg I wish there was an easy way to identify the module, so you may just have to trust the seller or get one from a vendor. A Tech II will be required to program a new control module ( the black electronic module) to your VIN, but if you just need the BMPV (the aluminum cylindrical part) you could replace that without programming. |
(Post 1583027021)
.....I took pictures of the 2010 module I bought that I was going to use to add traction control.
All years and models of the C6 have Traction Control!! Bob :flag: |
(Post 1583027021)
That picture is of the Bosch EBCM used in the 2009 and newer. I believe Howie's car is a 2008, which requires the ACDelco unit. The two are not interchangeable!!:nonod: Bob :flag: |
