Did anyone notice this about the c7 or am I blind?
When I took a closer look at the pictures of the red stingray at NAIAS it looked like the manual doesn't have an e brake handle?
Did they get rid of the e brake on the manual and put an electronic one or am I just blind? |
You must not be here often. Yea, it's an electronic e-brake. The button is located on the center console.
Here is a discussion on it. http://forums.corvetteforum.com/c7-g...g-brake-2.html Here is a photo of the e-brake control button. http://i390.photobucket.com/albums/o...psab649624.jpg |
Just more tech stuff to go wrong and make the car un-affordable to future owners.
Which could be a boom to older vettes without all the tech. Tech is neat so long as it works. |
Originally Posted by C7envy
(Post 1583050456)
Did they get rid of the e brake on the manual and put an electronic one ...?
Originally Posted by texvette2
(Post 1583050540)
Originally Posted by slief
(Post 1583050483)
An emergency brake that actually works and probably saves a few pounds as well.
I believe it works on all four brakes rather than just the rear two. |
Originally Posted by JoesC5
(Post 1583050665)
What happens when you're cruising down the highway at 75 MPH and your 4 year old grandson has his hand resting on the center console and pulls up the E-brake button?
Originally Posted by BlueOx
(Post 1583050623)
I guess you've never had a manual e-brake cable break or fail on you...:D
(Post 1583050540)
(Post 1583050665)
(Post 1583050665)
Good Question. Maybe some type of override, i.e., no E brake can be applied when the Car is moving? |
Originally Posted by MikeG37
(Post 1583050684)
Nothing.. well a warning light maybe.
In years past, once in 1963(1957 Ford) and again in 1982(1969 Corvette), I've had two hydraulic brake failures occur and had to use the manual E-brake to stop my car before running a red light in both cases. Sorry, but a waning light would have gotten me killed, whereas the manually operated E-brake(at any speed) got me stopped in time. |
Hopefully it works really well - seems like there were a lot of threads over the years about the C5 parking brake.
Originally Posted by alanhang
(Post 1583050732)
nothing. first of all you have to lift it up to activate. Second it doesnt operate once you start moving.
If I need to make an emergency stop while the car is in motion, because of hydraulic brake failure, does the floor pan have openings where I can drag my feet to stop the car(like Fred Flintstone)? |
Look at the up side, being electric it probably saves weight too I would imagine that there would be no cables, parking brake handle or extra brake shoes in the rear.
(Post 1583050684)
jas |
(Post 1583050732)
We'll have to see if GM's since reprogrammed the controller to disallow activation while the car is in motion. jas |
(Post 1583050483)
Originally Posted by jvp
(Post 1583050820)
That may be the case in your Z4, but it isn't in the 2009 Cadillac CTS-V I had. All four calipers were locked up. I tested it on an open back road with no traffic around me to verify it. And sure enough: the car slowed, violently.
We'll have to see if GM's since reprogrammed the controller to disallow activation while the car is in motion. jas Seems that locating the button on the dashboard to the left of the steering column would be better. If they lock it out when the car is in motion, then what happens if you do need to make an emergence application of the parking brake? While the parking brake might not be called an emergency brake, it sure is nice to have it if there is an emergency need to top the car. |
