which big brake kit
what kits have you guys found gives the most bang for the buck.
front and back |
I bought a used C6 Z06 set for $1000 last fall. I got the entire kit...calipers, rotors, pads, and lines. I refurbished them to look like this:
http://i104.photobucket.com/albums/m...ber2012086.jpg Check the C6 Parts For Sale section often....:cheers: |
Originally Posted by Cedarberry
(Post 1583669242)
front and back |
1 Attachment(s)
:iagree:
400 hp frc for the street, tracktime down the road. just recently purchased he car and the first mods i would like to do are the big brake kit with widebody in mind for the future. will put on new rims and tires with that.
Originally Posted by $$$frumnuttin'
(Post 1583671048)
I went with stoptechs but i do track my car quite a bit.
(Post 1583672875)
http://i67.photobucket.com/albums/h2...s/DSC_0004.jpg Right now I'm just planning on upgrading brake pads and adding cooling ducts like these: http://lgmotorsports.com/gallery/alb...BrakeDucts.jpg |
Originally Posted by jcsperson
(Post 1583673901)
If you're going to do serious track days, you might want to search through the threads on the Autocrossing and Road Racing part of the forum. One of the favorites is the AP Racing/Hardbar T1 kit. It's on my "some day" list.
http://i67.photobucket.com/albums/h2...s/DSC_0004.jpg Right now I'm just planning on upgrading brake pads and adding cooling ducts like these: http://lgmotorsports.com/gallery/alb...BrakeDucts.jpg to make the system work. Finally ended up using 2 electric blowers hidden behind the front bumper. All is well and I can turn them on and off from a switch. Good luck on your cooling project. |
ttt
I have a set of the big BREMBO cost over 7,k new. These or RED a guy had a set of BLACK one's for sale a few weeks back...will sale for 4300.00. Reason for the pull off is drag pack with 15,s on the rear.:thumbs: Robert
clif, sold a kit in here, mine are a full set front and rear just like what he had for sale. rotors brackets to mount them plus the SS brake line for the car also they come that way. Only diff is these I have or RED...Robert |
Brembo, 15'' 8 piston F, 14'' 4 piston R
http://i22.photobucket.com/albums/b3...10012copy2.jpg http://i22.photobucket.com/albums/b3...a025copy-2.jpg |
Originally Posted by JETZ
(Post 1583678439)
http://img43.imageshack.us/img43/440...0627190119.jpg
W/Hawk pads....Awesome! It should have came this way. |
Originally Posted by road pilot
(Post 1583676352)
Good luck with the cooling ducts on a C-5. It was torture trying
how many of you are runnin 19inch rims up front and 18 in the rear to clear the big brakes.
isnt there a problem with this set up, as far as the car recognizing wheel /tire height? |
(Post 1583680973)
isnt there a problem with this set up, as far as the car recognizing wheel /tire height? Car has no idea what size your rims are. You just need to make sure your tires are the right size for your rim to give the wheel stock diameter. Or you can change the wheel diameter in the pcm if you have an appropriate tuner. |
(Post 1583680973)
I went the C6 Z06 way so that replacements for anything are OEM, and should be around a lot longer than some aftermarket companies. (also, I got an employee discount..:D)
http://i144.photobucket.com/albums/r...ps288f0fb0.jpg Eventually, I swap these StopTech Sport Stops for Coleman 2-piece though...:thumbs: |
Originally Posted by WalterSobchak
(Post 1583681217)
Running 18/19 to clear my z06/GS brakes.
