Do you torque your oil pan bolt?
I was going to change the oil in my 2005. It will be the first time I have done this. I have my PF46 Delco filter and the Mobil One oil. But I was wondering how tight do I should torque the oil pan bolt. I have always just done it by how it feels. But since this car is more critical to me........You know what I mean? So, I was wondering if any of you torque your oil pan bolt. If you do, how tight should I tighten mine? Thanks.
I have been changing my oil for over thirty years and have yet to torque an oil pan drain bolt.....including the Vette. :hide:
Technically.....yes.....you should use the recommended torque setting. That being said, I've really only used my torque wrench to tighten lug nuts when changing wheels.
My motorcycle has an aluminum oil pan and after 13 years of changing oil at least twice a year the threads finally broke loose. Took it in and the dealer installed a steel helicoil. |
Originally Posted by R&L's C6
(Post 1583792526)
(Post 1583792526)
And that is the correct oil filter, right? How many quarts of oil should it take?
Did my first oil change on the weekend with a buddy and he googled the spec for torquing the oil plug. I would have never even thought of it.
Dave |
Originally Posted by netacoma2003
(Post 1583792541)
If you don't torque it down, it will come out. If you're asking about using a torque wrench on it - no need. It only needs to be 15-20ft lbs. So just snug it down.
That drain plug is no less or no more important than the drain plug on any other car. Snug it so it doesn't leak. |
AC Delco PF 46 is the right filter? And how many quarts of oil? Thanks.
Look in your owners manual !
Nope
Originally Posted by 01VETTECOP
(Post 1583793069)
I looked at several other posts on here and they all say that is the right oil filter. It replaces the UPF44. So, I'll use that one. Thanks for all the help, guys. I appreciate it.
Yes: I always use a torque wrench, except for screws.
(Post 1583792526)
I go by feel on something like an oil pan
Originally Posted by Jimmy W1
(Post 1583792740)
http://aoca.org/pdf/drain_plug_torque_2011.pdf 2005 owners manual states 5.5 quarts of oil - page 5-94 PF44 oil filter - page 6-13 18 lbs ft torque -first page of second link :cheers: |
Originally Posted by c54u
(Post 1583793832)
http://www.c6registry.com/technical/manuals/2005OM.pdf
http://aoca.org/pdf/drain_plug_torque_2011.pdf 2005 owners manual states 5.5 quarts of oil - page 5-94 PF44 oil filter - page 6-1318 lbs ft torque -first page of second link :cheers: |
(Post 1583793364)
I looked at several other posts on here and they all say that is the right oil filter. It replaces the UPF44.............
