Fob programming #1 short or long method?
I want to program my new fob for my C6..
The only fob I have is fob #2 (on the back) .. I've bought a new one with #1 on it.. Can I use the short methode ? Or do I need to do the erase all procedure ? Short methode: 1. Put drivers window down all the way, then turn car off 2. Trunk open 3. Glove box open 4. Put working fob on console next to shifter (the one you are currently using to drive the car) IMPORTANT. Also make sure no cellphones are in the car. 5. Put key in trunk keyhole and turn key five times in less than 5 seconds. 6. DIC will now beep and light up and say “Ready for fob 3”. 7. Put new unprogrammed fob in slot by glovebox with buttons facing right (passenger) side. 8. Wait and watch DIC. When it says “Ready for fob 4” it is done. Up to four Fobs may be programmed to the car total. 9. When all Fobs are programmed, push OFF/ACC (bottom half of start button) to turn off DIC. 10. Test all four buttons on fob and then take away all other fobs and check car starting with new fob(s). |
Long method and put the case with the #1 in as the first to be programmed.
Keep this handy.. >>C6 Fob Programming and Glove Box Slot Testing Procedures<< Elmer |
Originally Posted by eboggs_jkvl
(Post 1583905431)
Keep this handy.. >>C6 Fob Programming and Glove Box Slot Testing Procedures<< Elmer Bill |
Mmm what dou mean with 'access all of the dic key choices??
What are those?... |
Originally Posted by greenbeauty
(Post 1583906009)
What are those?... Elmer |
Exactly...#3 and 4 will only unlock the car and start it...seat position, radio stations etc etc will not be set as part of the deal. Use the full long procedure including the test of the glovebox slot...always a good idea before doing the long one.:thumbs:
