Having trouble installing HP Tuners
Had this before once but did something and got it working. I have a new desktop and laptop. Tried to install HP Tuners and neither one would "see the tuner" I looked through the HP Forum and saw about the A and B driver/channel installation in the device driver section but everything I have tried has failed.
I have tried the original disk (had to install framework again) to no avail. Tried the latest download from HP and can't seem to get the drivers installed. They will not install on their own. Any suggestions? |
PM me your email address and I'll send you the drivers.
Thanks, PM coming. Are they exe., zip, ...?
any error massages ?
Originally Posted by 8850
(Post 1584216554)
Originally Posted by Nasser_q8
(Post 1584323619)
From HP Forums, I checked the drivers in device managers and they are not there. |
Originally Posted by RLSebring
(Post 1584336767)
I think I will have some time tomorrow to try the drivers you sent. Fingers crossed...
No error messages until I fire up Tuners software then it says "can't find device". From HP Forums, I checked the drivers in device managers and they are not there. |
I actually had tried that before with no luck. I apparently did it wrong. Can you elaborate or is the process explained in one of the links you provided? I may have to stay up a little longer now to try this.
(Post 1584336775)
open the control panel and choose devices and the click on hptuners and choose update from web. that's all what you have to do good luck :cheers:
(Post 1584336804)
what windows software are using ? |
7 on desktop and 8 on laptop.
let me know if it works
Had a wild hair to try this tonight. Luck was on my side as the drivers updated without a problem. What a PITA it was in the past...
Thanks for your help. I can tune again. :) |
Yeah microsoft recently integrated our drivers into their automatic updates so as long as you have automatic updates turned on the drivers should, now, automatically install. No downloading drivers from us, no control panel modification, no nada, just plug it in and go :)
